Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Arrow Racing GTR .21 Engine Thread >
Old 06-08-2013 | 06:28 AM
  #1171
Mark Erce's Avatar
What restrictor are most of you guys running? Or what should I start out with? I run on a medium size track(30 sec) average lap time, low-med bite track and gets pretty hot here.
Mark Erce is offline
Old 06-08-2013 | 03:44 PM
  #1172
I run 7mm restrictor. If it gets warmer than 25~28 degrees C, I switch to P4 plug.
Eivind E is offline
Old 06-08-2013 | 05:31 PM
  #1173
ark champ's Avatar
I need some info on the new GTR-II. Can someone give me the ball park needle settings, recommended plug and does it like to be rich on bottom and leaner on top or the other way around? Love it so far but feel it has alot more in it.
P.s. I'm not the best tunner. Lol. Thanks
ark champ is offline
Old 06-08-2013 | 07:33 PM
  #1174
22Racer's Avatar
Mid - 2 turn out from flush at 2 oclock
Low - 1 turn in from flush
hsn- keep leaning it until you get good top end speed and god temps. I think most use a p3 plug.
Rex
22Racer is offline
Old 06-08-2013 | 09:14 PM
  #1175
ark champ's Avatar
Thanks Rex, I'll give that a shot. Any idea what temps people are running?
Old 06-09-2013 | 08:45 AM
  #1176
22Racer's Avatar
I dont run the Arrow very often but I think 230-250 deg.
Rex
22Racer is offline
Old 06-09-2013 | 02:20 PM
  #1177
Mark Erce's Avatar
How is the VP-Pro Ultra Hot P3 Glow Plug working in this engine? Do they perform the same as their OS P3 counterpart?
Old 06-10-2013 | 06:35 AM
  #1178
VPProUSA's Avatar
Mine runs 260-280'F. Anything under 300'F is fine as long as there is smoke and no bogging.
VPProUSA is offline
Old 06-13-2013 | 02:04 AM
  #1179
Whats the bearing size for the GTR plus 21?
8scale_racer is offline
Old 06-13-2013 | 05:33 AM
  #1180
VPProUSA's Avatar
14x25.4x6mm
VPProUSA is offline
Old 06-13-2013 | 06:20 AM
  #1181
Originally Posted by VPProUSA
14x25.4x6mm
And the front?
Old 06-13-2013 | 06:33 AM
  #1182
VPProUSA's Avatar
Same as all .21 engines.
7x19x6mm
VPProUSA is offline
Old 06-14-2013 | 03:35 PM
  #1183
Thanks, should have known
Old 06-15-2013 | 08:26 AM
  #1184
stallen50's Avatar
Anyone have put the arrow piston and sleeve in the hara speed yet?
stallen50 is offline
Old 06-15-2013 | 10:41 AM
  #1185
I really don't think they'll fit. That's an XZ-B engine.
From what I know this will only fit a VZ-B.
I put mine in a Ninja case with an OS carb. Runs great!
So possible candidates would be VZ-B (and Speed vz-b), JQ Engine, Ninja.
I don't really know if there are any others.
Eivind E is offline
