Argus USA Engines Thread
#902
So, ordered an 0801 from Taiwan. Who knows when it will get here. In the meantime, I tried a 2047 today. Best I've tried so far. Still not a powerhouse though.. Run-time maybe not quite as good as JP-4, but more power mid-high I would say..
#903
Well got 2 of the first argus engines in for a resizing this week, one had 8 gallon on it the other had 7 resized and put front bearngs in them and a resize. Rod, crank still in great shape. That is a s good as it gets these days, most engines cant get past the 4 gallon mark without needing something replaced.My customers all have had only positive feedback on these engines. And the Mod engine as well. I keep seeing and hearing about Our Mod pull just about anything on the track.
I currrently have almost seven thru mine and it is still going strong. These are the longest lasting engines I have had in a long time.
Lance
RcRenew
Well ,,,I guess you just answered my ? on longevity.This motor is worth every Dollar!
#905
Leave it factory. I was told messing with the shims plays alot of factors as far as timing etc. Leave what it came out of the box with. Some engines come with a break in shim, Argus i dont think does but if otherwise only the break in shim should be added or removed... Correct me if im wrong, but i think shimming has alot more to do then just button gap...
#907
Thanks,
Lance
RcRenew
#908
I see these engines outlasting most of the more expensive "big name" engines and providing the same if not better performance. You really cant go wrong with the Argus.Thanks,
Lance
RcRenew.com
#909
Well, RIP Argus.. It's been a great 12 tanks...
JK.. I hope.. Was running some more fuel through today, after installing a 17T CB(up from 16), and decided to throw the body on. There were a lot of people there watching, and my SC8 was obviously way cooler than every other RC there..
Seriously, these people were really enjoying it.. Anyway, body on, hit the gravel path, did some high-speed runs, got nervous, took the bod off, checked the temp - 345...
Don't know if it's toasted yet or not.. Was running great with +1 on the CB and the 2047 pipe.. I am NOT though a fan of gallon break-ins.. Not only does it take forever and is boring, but it's just expensive. I won this Argus in an auction for €95 + €11 shipping. A gallon of fuel costs €44.. To pay %40+ the price of the engine just for break-in is stupid..
Do like the engine though. We'll see if she still runs..
0801 is still on the way from Taiwan...
....Don't know if it's toasted yet or not.. Was running great with +1 on the CB and the 2047 pipe.. I am NOT though a fan of gallon break-ins.. Not only does it take forever and is boring, but it's just expensive. I won this Argus in an auction for €95 + €11 shipping. A gallon of fuel costs €44.. To pay %40+ the price of the engine just for break-in is stupid..
#910
Just getting it hot should not really bother it too much.... Being lean and hot is what can do damage...Your tune may have been good, but your body was not allowing enough air flow over the head..As long as the tune is good 345 should not really hurt it....These things get much hotter then that in the combustion chamber anyways....
#911
Just put some ARO in it.. When rotating the flywheel it still gets stuck at TDC if you even get close.. So, still tons of pinch.. Piston has a nice copper color - the plug a tiny bit browner maybe than it was before.. No wetness behind the flywheel..
Maybe time for a cooler plug(P4)..? Currently an OD 97T...
#912
#913
#914
I used to run Sidewinder %25, which had lots of oil, and my engines generally ran very cool(though mostly basher SH engines - my Caster Grenade ran hot for the first gallon - 290ish on av..) The LHS stopped selling it though, so I had no choice but to switch to Tornado Car %25.. So that's what I run now, and have only run in the Argus. Not sure on the oil - %12 maybe? (it's not the Competition blend..) Defo less lube than the SW.. I liked the SW better..
I think the LHS has Tornado %30. Not sure about that though. Have never run %30 before. Also not sure about the price - they might only sell it in 2.5L canisters. If they sell it in 4L canisters like the %25, and it doesn't cost much more, I would maybe consider it.. Doubtful though. I'm currently running like seven engines I think, all used to %25, so don't want any huge changes all at once..
#915
Ran my Argus today finally a dry day and ground was dry well parking lot was. Took it to school parking lot and ran 5 tanks thru it. Using Sidewinder Team strike at 30% with the Orion 2013 pipe the temps were at 230-235. Its a screaming beast of an engine. If the F0801 is better than the 2013 woooha
im gonna get me one of those pipes.
1Likes
