Like Tree1Likes
Argus USA Engines Thread
Old 10-19-2015 | 03:19 PM
  #2011
Originally Posted by 22Racer
You can try but it could leak, it depends on if you gorilla tighten the Os plugs. The taper is the same but the Os have less contact and can distort the head button. A Nova 5 might work ok but the 6 is pretty cold for an Argus.
Rex
That's disinformation, all the Taiwan engines are designed to run the OS style plugs and most of them come with one or a copy. So it is infact the complete opposite, why would anyone choose to run a nova plug in it?
Eivind E is offline
Old 10-19-2015 | 04:43 PM
  #2012
22Racer's Avatar
We went through this a few years ago on here. (search for it) I checked taper on a optical comparator and all plugs I checked at the time were the same taper. The Os plugs have relief where the taper meets the threads. Os does not tap their head buttons as deep as say a Nova. Putting a Nova plug in a Os will sometimes stop before seating the taper. Os plug in a Nova works fine but with the relief it tends to distort the head button so if you go back to Nova plugs it may leak.
Rex
22Racer is offline
Old 10-20-2015 | 08:40 PM
  #2013
22Racer's Avatar
Here is the last few minutes of the 1/8 buggy A-main. Kendall is running a modified Argus R8. He ended up 2nd behind Adam Drake.
https://www.youtube.com/watch?v=QvepUVfyyf0
22Racer is offline
Old 10-21-2015 | 09:19 AM
  #2014
lilstewie's Avatar
Thumbs up
Nice Run Kendall!!!! He has that thing dialed in!!! Does he run the 0801 with that setup?
lilstewie is offline
Old 10-21-2015 | 10:18 AM
  #2015
Jeff Werner's Avatar
What Mod did you do on that R8? What plug do you guys like in your R8?
Jeff Werner is offline
Old 10-21-2015 | 10:38 AM
  #2016
Nice drivin'!.. Cool clip. Makes me want to go burn some nitro...
Herrsavage is offline
Old 10-21-2015 | 01:59 PM
  #2017
22Racer's Avatar
I did this engine for Kendall lat year and he only ran it 3 times last year and 3 times this year. Every time out it we were able to pit at 9 minutes and it has great useable power.
For the mod on his R8 I ran the D52 style full circle crank with added crank timing. It also has a modified backplate and an Avid ceramic rear bearing. There is no dremel cuts in the engine, all stock ports.
Kendall was running a Orion 2058 but the last 2 races he has ran the 0801, the 0801 is more bottom end. About the same mileage with either. Kendall uses the 8mm carb insert. We use Od 97t or 77t plugs and honestly I may have changed it once in the 6 weekends on it.
Rex
22Racer is offline
Old 10-21-2015 | 02:09 PM
  #2018
22Racer's Avatar
I always get a kick out of watching things on pit lane during events. I see engines I hear about here on Rc tech with big claims of 12 minutes etc. I saw last weekend on of the engines engineered for fuel mileage come into the pits at 6 minutes! Adam Drake and Kendall were the only 2 to go more than 7.5 minutes. It would be great to pit at 10 minutes and I think we could with Kendalls setup but it is just too close and I dont like running out of fuel. It is however really nice to wait 3-4 laps after everyone cycles through and you have a nice clear pit lane to pit.
Rex
22Racer is offline
Old 10-21-2015 | 08:09 PM
  #2019
I really enjoy my stock r8. What do you get with the mod you created on the modded r8? Sounds like a cool combo.
Old 10-22-2015 | 06:23 AM
  #2020
rider313's Avatar
Rex
I was the only one besides Adam to pull off 10 minute stops last weekend from all the nitro mains. I also found it funny all the guys with "high Mileage" engines only doing 7:30 stops.
rider313 is offline
Old 10-22-2015 | 02:03 PM
  #2021
22Racer's Avatar
I thought you might have went 10 also Danny, did it bite you in Truggy? There also seemed to be alot of flamouts in the mains but I wasnt sure if it was people trying to push mileage.
Rex
22Racer is offline
Old 10-22-2015 | 02:04 PM
  #2022
22Racer's Avatar
The biggest change with modifying the R8 is more mid and top end.
Rex
22Racer is offline
Old 10-23-2015 | 04:22 AM
  #2023
rider313's Avatar
Rex
For sundays mains i went with a different engine in truggy, and only did 8 minute stops for not having time with this engine on the track. Stupid me never changed the plug when i dropped it in, half way through the A the plug decided it had enough.
rider313 is offline
Old 10-23-2015 | 03:16 PM
  #2024
helllo i have an argus a5 engine using 25% rb fuel with edit efra 2032 pipe and long manifold 8mm venturi in carb nad novarrosi c6tcq clow plug.engine running about 100 to 110 celsius temperature.great power no flame out but i need more runtime.the best i get is around 8 minutes.if i use 7mm venturi i will be able to get 10 minutes runtime??
kostas xray is offline
Old 10-24-2015 | 08:41 PM
  #2025
22Racer's Avatar
It should be running a little warmer than 110 degrees, try leaning it out some more. with 25% you should take out one .1mm head shim also. I am not familiar with the 2032 pipe though.
Rex
22Racer is offline
