Argus USA Engines Thread
#1981
i have an argus a5 engine and i want to know what fuel mileage you get from that engine for me is 7-8min in my track.i use c6 novarrosi glow plug 25%rb fuel.engine runs very good good power temp is in 105 celsius.i use 8mm venturi.i think my fuel mileage is not good any thoughts?
#1984
with a 8mm and that pipe 9 minutes is most i would expect a fast driver to get. Drop down to a 6mm and the 801 pipe and the same fast driver can get over 10 minutes easily.
#1986
Rex
#1987
ok i will try to lean hsn just a bit.if i remove 0.1 shim that will cause more stress to the motor???my engine seems to have very good power actually no other car can pass me in the straight,but it seems that i can lean the top end more.my track has a small straight.
#1990
Rex
#1991
Sorry to not update everyone lately. I have not had the chance to race in awhile (that changes this Saturday. . brrrapppp), but wanted to share a pic of my truggy with the R8, and buggy with the R83.
My first race with the R83 went ok. It was still coming in (still is a bit) and in the second heat I was running really well, then it went rich and I ran out of gas. After that, it became more steady (richening only a little as I ran the 3rd heat and main). I did not finish well (my driving was BAD) but the motor ran great! I was pitting at about 8 1/2 mins on a big track, and I suspect it will do 10mins easily as it finishes breaking in. Love my Argus motors. I will share how everything with both motors goes this weekend.
#1992
Attachment 1302532
Attachment 1302532
#1994
#1995
I tried a short double bend 41032 on my truggy with the 0801 pipe on my .23 last race. It had great bottom and it didnt hurt the top much either, I liked it better that the std. 0801 header.
Rex
Rex
1Likes
