More bottom end on V-Spec
Old 10-20-2010 | 05:55 PM
Default More bottom end on V-Spec
Hi Guys!
I would like to get some more bottom end power out of my V-Spec, it has five and a half gallons on it and Im running a JP-4 pipe (this is probably the main problem, if so please recommend a different pipe, dont really want to spend the 100$ on the OS 2050/60), Dynamite max life aluminum shoes with 1.1 springs (dont think I can get more bottom end here...).
It gets very good power when on the lean side, properly tuned around 230F it gets decent top but very little bottom. I will be getting it repinched soon once I get a new Werks B5 so if that might be the problem I may leave it as is...
Thanks!
Nesal is offline
Old 10-20-2010 | 06:06 PM
shanty140's Avatar
Just so you know. You can get a Losi RE-11 pipe which is the same pipe as the O.S. 2050 for $64 from amain.
shanty140 is offline
Old 10-20-2010 | 06:07 PM
houston's Avatar
Originally Posted by Nesal
Hi Guys!
Thanks!
1.1mm springs can actually cause a little clutch slippage , could be part of the problem , a vspec after 5 gallons normally doesnt have a whole lot of compression and that can cause a weak low end also . check rod/crankpin fitment make sure it is in tolerance ,bearing condition and then send piston/sleeve set off to raya racing if it needs resizing/reconditioning , you will be very happy with rays work , very very good
and the jp-4 pipe is a great low end pipeset
houston is offline
Old 10-21-2010 | 06:15 AM
Thanks guys, will try weaker springs and get a re pinch as soon as I get my new engine!
Would a Dynamite 053 better suit this engine or stick with the JP-4? Thanks for the heads up on the Losi!
Nesal is offline
Old 10-21-2010 | 06:27 AM
token's Avatar
JP4 sucks on a vspec
Try your clutch set up. I run 2 black and 2 green, OR 2 green and 2 gold depending on the track.
I have been running vspecs for 3 years now, I do not run ANY JP pipes as they all suck fuel AND they dont run on a nice crisp power band.
I run the RE11 pipe, but my fav is the dyn 053. Im not a super pro that knows it all, but I have been running the same setup for a while, I have played with setups, pipes, fuel, ect.
I dont think you need to spend that much on a pipe. Either the Losi Re10 or 11 would do just fine.
token is offline
Old 10-21-2010 | 07:05 AM
Torian4000's Avatar
I'm pretty sure that if your Vspec has 5 gallons though it, it probably needs a rebuild and pinch. It may be time for a new crank as well. I ran a Vspec this past summer in my MBX6T for two months. I used a Dynamite 007ht and 1.0 springs. It had tremendous bottom end and decent mid to top end power.
My vspec lost compression after 2 1/2 gallons. I had it rebuilt and pinched and it was good as new. My engine guy did say that I'd need a new crank after another gallon or so. If I were you I would have it looked over by someone who can pinch and rebuild it for you.
Torian4000 is offline
Old 10-21-2010 | 07:07 AM
jwm2's Avatar
You can buy a losi tuned pipe on ebay for about $20.
jwm2 is offline
Old 10-21-2010 | 07:16 AM
jmaxey51's Avatar
i tried a 053, its really smooth and not good run time... RE10 or RE11 would be good or Dynamite 007 will give it bottom but idk about top or run time.
jmaxey51 is offline
Old 10-21-2010 | 07:18 AM
Do-Over's Avatar
I really can't believe I'm saying this but I think your confused Monty. I think the JP-1 and 3 are low end and 2 and 4 are mid to top pipes.
Do-Over is offline
Old 10-21-2010 | 07:23 AM
token's Avatar
I have heard all kinds of stories on vspecs.
Now from running them for the last 3 years, my engines have ALL reached 9 gallons. I have one with 11 gallons on it. (and it still fires up)
Some key point I believe lead me to have such luck is:
1. Make sure the piston has been place DB after each run period. It is now a habit.
2. Tune correctly!. And most of the time, that does not require a temp gun.
3. BDC or DBC what ever you wanna call it.
token is offline
Old 10-21-2010 | 08:20 AM
jmaxey51's Avatar
JP-1 is bottom
JP-2 is mid to top
JP-3 is bottom to top (kinda combining JP-1 and JP-2)
JP-4 is smooth bottom with more top end
straight off the website (i was just adding to yours, Do-Over)
jmaxey51 is offline
Old 10-21-2010 | 09:23 AM
The only JP pipe worth running on a V-SPEC is the JP-3 but you will sacrifice mileage. I suggest buying a 2050 if you want to get the most out your V-SPEC. You can probably find one for $40 or $50 on ebay or in the for sale thread. The RE-11 pipe is very close to a 2050 but the RE-11 manifold is completely different from the 2050 manifold so performance is comparable but still not a 2050. Spend the extra $ and you will have more low end than you know what to do with.
ForwardBite is offline
Old 10-21-2010 | 10:56 AM
Jaz240's Avatar
I noticed nobody addressed his clutch. If you are using the standard 3 shoe set up you can try a 4 shoe (m2c, Werks, etc ) they give allot more bottom end snap to any engine
Jaz240 is offline
Old 10-22-2010 | 08:15 PM
Get that JP-4 off it!! Run the re10 or 2060, easier to tune and runs better than the 2050 IMO, or has more of a tuning window, so if it's not "perfect" with the 2060 she will still perform.
If you are getting 2.5 gallons out of a vspec there is something wrong, not with the motor, 3.5 and new crank?, sounds like your engine guy wants Some $$$. Run the extra head shim with 30% and compression and power will last till 6-7 gallons, ever since I put the extra head shim when new or close to new OS motors all my motors keep good compression into 5-6 gallon mark, running them at 250 average with a 2060 30% fuel.
Also if you out a speed crank in you will loose that insane bottom snap, it will still have beautiful bottom, but not stock bottom. My vspec STOCK can be a lil much at times, B5's Pshhhh....and it'll stay running
If your looking for a new vspec crank for a good price send me a pm.
Andy
02maxima18 is offline
Old 10-22-2010 | 08:53 PM
The 2041 from RMV or EB Mods is a great pipe also.
The 2060 has a softer smoother power band and the 2041
gave it alot more low end and a hi-revving top end.
http://www.amainhobbies.com/product_...ine-Tuned-Pipe
rageworks is offline
