"the engine break in bible"
#406
Does every engine can use this method? I was breaking in an OS like this but LHS told me my new Alpha has to break-in differently.
#408
[deleted]
#410
looking for some imput on the advanced engine break in vid on youtube i came across. fairly new to engine break ins and tuning. any info would be great on this method.
#412
Can vouch for this, my Alpha was fairly tight too, actually, today was the first day ive started it without having to unjam from TDC during starting, and one other thing I've found, is the more fuel you put through it, the more you need to lean off to keep the temps up. Once the temps started to stabilize, i noticed the engine starting to free up a bit too, so guess it just goes to show, that like tuning, the engine will tell you whats going on with it.
#413
Question...
It appears there are two different break in methods in the original post from Monty, I was wondering which was more preferred, the idle on the box for three sessions of a couple min while cooling in between, or the run it on the ground from the start method? It's not clear to me after 10 pages or so
#414
Monty this is travis from the Wenatchee nct race, I was pitting with Marcus!
#415
either method is just fine
keys to break ins r
good lube pkg fuel
preheat
do not over rev
do not "blip" throttle during break in
heat cycle is my preferred method
three 5 min sessions with head cover on
three 10 min sessions no head cover on ground with body on , be nice to throttle
three thirty min sessions
cool in between , piston out of "pinch zone"
all the while try to maintain temps in the 200 range , measure temps with a good temp probe otherwise your efforts are wasted
#416
sup bro , hope all is well
keys to break ins r
good lube pkg fuel
preheat
do not over rev
keys to break ins r
good lube pkg fuel
preheat
do not over rev
#417
Thank you guys, I'm a few days in, it is the nova Clio p5 and tonight I will be starting the 30 min sessions, I set my end point so I could not go full throttle and have been preheating it, cooling, and my temps are above 200 usually 210 but I have hit 230 a time or two in the second ten min session. All seems to be going well
Again thank you
Again thank you
#418
keys to break ins r
good lube pkg fuel
preheat
do not over rev
keys to break ins r
good lube pkg fuel
preheat
do not over rev
im breaking in a new but older picco boost. im trying your method. ive done the three 5 min intervals on the box and the only thing i do not have is a comp heat cover. i was using a cut down coozy cover and a heat gun to maintain the temp. i was able to. stay at 195 to 200 without the gun but did have to go in a bit on the lsn. bout 2 hours from factory setting. it idled very well with good lubrication out the pipe. im now into the 30 ft runs on the ground. the engine idles well when it comes back and stays at 205 to 210 without the cover on it. ive done 2 10 min runs on top of the 5 min box idle runs. yust wondering how many tanks of this i have to go. all ive done is 2 1/2 so far and i know thats not near enuf for a proper break in. again its working perfect so far. just wanted to make sure im doing this corectly. first solo break in for me
#419
What's up Monte, can't believe this thread is still going strong after all these years! Never would have guessed that S-Grid post would ever get so famous, lol.
Hope you're doing well. Drop me a line sometime.
