Like Tree5Likes
"the engine tuning bible"
Old 01-06-2013 | 09:29 PM
  #376
Originally Posted by JoePit
Haven't read that in a while but Ron leaves out the part that when you start leaning your HSN you need to richen the LSN.If you don't you risk having a lean LSN compensating for a rich HSN. Every adjustment you make to the HSN will affect your LSN.
I c so it make sense to lean the hsn first since it leans the lsn? Starting off with a rich stock setting?
I just read that novarossi you run the lsn first? If I do the lsn first then lean the hsn then go fine tune the lsn?
When I'm in pit lanes I hear ppl say lean my bottom out etc...is that ok if they don't richen the hsn?
Inforthewin is offline
Old 01-23-2013 | 07:16 AM
  #377
Can you break in a engine in the winter time or wait for warmer temps.
miket is offline
Old 01-26-2013 | 02:49 PM
  #378
sschultz's Avatar
yes. wrap tin foil on head and moniter temps....
sschultz is offline
Old 03-07-2013 | 03:27 AM
  #379
TomErickson's Avatar
Speaking of winter....should I go from a P3 to a P4 glow plug if I am racing in temps below 50 degrees? What is a good rule of thumb? Should I change Nitro % from 30% to less as well?
TomErickson is offline
Old 03-07-2013 | 01:47 PM
  #380
sschultz's Avatar
A p4 would be cooler than a p3. I wouldn't change a thing. You may have to richen up your needles a bit for the air temp but that's it...
sschultz is offline
Old 03-09-2013 | 07:16 AM
  #381
rider313's Avatar
A P4 is a hotter plug then the P3..... If its Cold out the P3 will be fine. ON the very hot and humid days, the P4 will shine.
rider313 is offline
Old 03-09-2013 | 07:17 AM
  #382
Maximo's Avatar
Actually P3 is indeed hotter then P4
Maximo is offline
Old 03-09-2013 | 10:05 AM
  #383
rider313's Avatar
Well than I have been mislead.....
rider313 is offline
Old 03-09-2013 | 11:14 AM
  #384
houston's Avatar
its all kind of misleading as some plugs that are rated to be a "hotter" range actually work as if they are of a "cooler" range , many designs of plugs and thats why they all act differently . there is the metals used in the filament wire and the size of the orifice , these things are huge in how the glow plugs run .
and most all plug manufacturers rate there plugs from hot to cold by lower numbers to higher numbers
hope this helps a little guys
heres a little experiment for ya , dont touch a needle on your engine while doing this
start wherever you like in the heat ranges and brands , get engine up to temp , run it for a few minutes on the street , varying throttle but not necessarily WFO , now bring it in , switch plugs go do similar throttlings , repeat this process over and over with all differrent plugs , make notes or wtvr on how each plug effects the tune you never touched that was hopefully good to race with in the first place . you will see a correlation between the cold plugs and how they act , hot plugs and how they act and so on and so on
houston is offline
Old 03-29-2013 | 11:13 AM
  #385
Originally Posted by SteveP
Let the engine warm up, then rev the engine up a couple of times to clean out any excess fuel in the crankcase. Put the car up on pit wall (if you're at the track) or on a car stand, then pinch the fuel line. If the engine stalls in less than 6 seconds the low-speed needle is too lean. If it takes longer than 8 seconds, it's too rich. If the mixture is too rich, you may also experience a considerable increase in engine rpm (hence the reason for getting the wheels off the ground), which tells you that the idle speed is too high. So, if the engine runs on for a long time after pinching the fuel line, lean the low-speed needle and reduce the idle speed. You want the engine to run 7-8 seconds after pinching the fuel line, and without a major change in engine idlle speed. It will rev up some, but not a lot, if the low-speed needle and the idle speed are set correctly.
Quoting an old post here, but when pinching the fuel line how far away from the carb should you pinching? Obviously the farther away from the carb, the more fuel will be in the lines to run and that can throw off the timing of the pinch test.
Thanks.
nofreee is offline
Old 03-31-2013 | 07:02 AM
  #386
Novarossi 21-5K. Engine starts up fine. runs good on the bottom and decent top. I noticed that once it warms up, when we bring it in, the idle is very high. to the point where the clutch is engaging. temps are in the range of 215-230. can anyone give some direction?
No leaks in fuel line or tank.
Idle gap is set @ .5 or so. This was set without the venturi.
All gaskets are new.
Thank you
brmena101 is offline
Old 04-07-2013 | 03:44 PM
  #387
sschultz's Avatar
Thank you
Found the same problem today on one of my mills. I'm thinking a bad front bearing, the seal on it. That is where I would check. You can spray wd-40 behind the fly wheel when it's at idle to be sure. It should change the idle if not kill the engine if it's leaking...
sschultz is offline
Old 04-08-2013 | 01:48 AM
  #388
nathanjohnzrc's Avatar
Wow, Houston, really this is a great article. Really this is a perfect guide for everyone. I really appreciate you on this step by step guide. Thanks for sharing this nice post. Please keep it up.
nathanjohnzrc is offline
Old 04-12-2013 | 04:16 AM
  #389
morgoth's Avatar
How do you know for sure that balance between the HSN and LSN is right?
My mate and I have the same car, engine, clutch, plug, fuel but our motors are tuned different. His is leaner on the bottom and richer on the HSN. Mine is richer on bottom and leaner on top. Both engines run around 100-105°C after a 15min main.
Mine has a high idle for about 16-18 seconds and then drops to a lower idle. The engine responds very well on the box. The tires balloon almost immediately.
morgoth is offline
Old 04-12-2013 | 06:08 AM
  #390
houston's Avatar
Pull the trigger nice n slow from fully closed on the slide barrel to fully open , there shouldnt be any major hesitation or an "unsmooth" / "hiccup" anywhere in the throttling. Only nice smooth transitions from bottom to top
Dont bother with the pinch test , use the 20sec idle test
houston is offline
