Like Tree5Likes
"the engine tuning bible"
Old 10-08-2010 | 08:23 PM
  #256
houston's Avatar
gonna sticky this again?
thanks jeremy
houston is offline
Old 10-08-2010 | 08:29 PM
  #257
J.Whiting's Avatar
Super Moderator
From: a very small town in wisconsin that is in the middle of absolutely no where
sent you a pm. yes it will by monday when everything gets sorted out..
J.Whiting is offline
Old 10-08-2010 | 08:47 PM
  #258
tc5 man's Avatar
Originally Posted by Do-Over
I have done the research on these and I can tell you your last example is correct. For the first part with a Long needle you set the idle and LSN first and then the high.
is this with every engine ? i though you set the idle than do the main needle than the low end needle ?
i run a rb hobby 9 (s5 ) sport engine.
tc5 man is offline
Old 10-08-2010 | 09:01 PM
  #259
Do-Over's Avatar
This is for Go based engines with long LSN but can be used with short too if you know it well.
Do-Over is offline
Old 10-08-2010 | 09:07 PM
  #260
deadmancourt's Avatar
i have ALWAYS tuned my engines this way(whatever the BRAND is) except OS i have NEVER tuned an os
deadmancourt is offline
Old 10-19-2010 | 11:37 AM
  #261
Am i right in thinking that as long as the revs rises slightly when doing the pinch test when fully warm, that the lsn is set slightly on the rich side or even ideal? Or is this just that you have set the idle gap correctly?
If an engine has a 2 stage idle (high the low) is that indicative of a rich lsn?
Sorry for the umpteen questions its just that everytime i get it right in my head i reread the entire thread and start second guessing.
AndyF is offline
Old 10-19-2010 | 04:46 PM
  #262
Do-Over's Avatar
The pinch test is for the LSN and the idle gap. How high it revs is idle gap. Should only rev up slightly, like 500 rpm's. How long it revs is rich or lean. Should be about 7 secs. on the long LSN's, 4 or 5 on the shorts. Also should be done with a warm engine, not a hot one. I believe this is correct but sometimes I dyslexic so you may want to wait on a confirmation on this.
Do-Over is offline
Old 10-20-2010 | 07:14 AM
  #263
Flanno's Avatar
correct
Flanno is offline
Old 12-03-2010 | 11:05 PM
  #264
MassiveMods's Avatar
Well yes and no. 7 seconds is an average for the Go carbs. Nova based carbs you want a 10 to 12 second pinch. same with OS carbs. So it depends on the carb and the needle jeting and taper angle.
What is best to do no matter what carb you have is tune the LSN and idle gap first before you do the HSN. If youre not sure of the LSN pinch time go for 10 seconds to be safe.
What pinching does is lean the LSN setting to un mask the true idle gap setting. then once thats sorted the HSN can be tuned and then you may re visit the LSN and idle for a finer tune as the HSN will effect the LSN setting.
the times given EG 7 or 10 seconds takes into account variation in heat and HSN settings. once that all sorted and the engine is hot you will find the LSN setting has decreased down to about 2 to 3 seconds which is safe.
Remember when you get lean bog at any time ( usually at half tank ) richen the HSN .. NOT the LSN ..
MM
MassiveMods is offline
Old 12-06-2010 | 08:03 PM
  #265
l3asher's Avatar
Does anyone have this is a pdf or word doc?
l3asher is offline
Old 12-07-2010 | 08:20 AM
  #266
You dont need a tuning guide you have a Derek. LOL
This method will work on your OS carbs really well though.
matrixmike28 is offline
Old 12-07-2010 | 04:05 PM
  #267
houston's Avatar
http://www.rctech.net/forum/8075559-post1.html
on the front page for you guys
houston is offline
Old 01-16-2011 | 12:54 AM
  #268
Dougoilman661's Avatar
What ideal pinch test on Os engines? Specificlly a 18tz.
Dougoilman661 is offline
Old 01-26-2011 | 12:56 AM
  #269
Hello, i have a GO 21-5port nitro engine. When there is 10-20% Nitro fuel left in the fuel tank the engine performance is much better then when there is much fuel in the tank. Can someone tell me why? Shall i lean the needles or do i have airleaks, can the lengt of the fuel line have something to do with this? I want the engine to run like it does with little fuel all the time.
/Regards Peter
sumpan77 is offline
Old 01-26-2011 | 01:05 PM
  #270
/Regards Peter
yes, you are a tad rich on top..but only lean in 1 hour increments....meaning if the needle was a clock, only adjust 1 hour at a time......the Go high speed needle is VERY touchy....but once you get it dialed, it will GO
