NEW OS 21 XZ-B and Speed XZ-B
#4876
So I was looking at the new xzb v2 and the piston rod and sleeve shares the same part number as the speed spec 2. So is there a new speed motor coming out?
#4877
dear all, sorry if i double post. i already have os spec 1 engine, and i want to replace the piston - conrod - sleeve. and its my question, can i replace it with the os spec 2 part, because my LHS only have parts for os spec 2.
thank for the help
thank for the help
#4879
Con rod is also different. Although I have both side by side here at the shop and I cannot visually see any difference other than maybe the oil duct is about 1mm longer for the spec 2. I have not measured any of the bushing sizes though but laying one on top of the other they appear identical.
#4880
#4881
anyone compared the performance difference between OS 21 XZ B Ver 1 and Ver 2?
#4882
So now I must buy the spec II engine ? Hehehe, maybe I will think twice before I buy it, because I'm a min budget racer hehehe.
By the way, thank you all for the info.
#4884
Spec II has a shorter conrod and the piston sits lower in the sleeve. If you use the Spec II setup in your old speed you will damage your piston becasue the backplate is new. Piston will heat the backplate.... So, be my guest and try...
#4886
Is the OS made motor?
ZR.21X Spec 2 High Competition Off-road Engine
http://www.stormerhobbies.com/cgi-bi...cs&pn=LRP32111
amain
LRP ZR.21X Spec 2 7+1 Port Off-Road Competition Buggy Engine
[LRP32111]
http://www.amain.com/product_info.ph...n-Buggy-Engine
Found it
Picco micromotori from Italie
Picco.
amain
[LRP32111]
Found it
Picco.
#4887
os made
amain
[LRP32111]
Found it
Picco.
amain
[LRP32111]
Found it
Picco.
the LRP ZZ.21C is os made ,3 ports,same as gen 1 speed !
#4889
I was also looking at the "under the hood" pics on neobuggy of Tessman's vehicle. In one pic of the engine, the HSN sure looks cranked down lean. Is this normal?
I believe this is the right pic for Tessman.
