NEW OS 21 XZ-B and Speed XZ-B
#3992
Thank you for your answers.
I looked at what I could get in France (I am French ) and it has pretty bad. The exhaust pipe 2058 and 2090 are only available with exhaust manifold. The 2058 is provided for engines Orion/Nvision and the 2090 before Alpha engine.
It seems to me that the OS engine need specific exhaust manifold. This means that I have to buy a specific OS exhaust manifold more or those available with both exhaust pipe are compatible with my OS ?
Thank you for your help and excuse my modest mastery of your language.
#3993
@trazom:
it's my impression that all engine manufacturers use the same style exhaust output, except Picco (who also make Reds, Vox, Xceed and probably others?) who have a downward angled one.
Hence the manifold included with the pipe should fit.
#3995
Thank you for your help.
I thought the OS engines had a type of exhaust manifold different from other engines.
I'll definitely take a 2090.
Thank you again.
Thank you again.
#3997
Have or anyone tried a 2050 on xzb yet... weathers turned for the worst in my area so i wont get a chance till spring for any true testing but i was just curious as the 2090 and 2050 have a very simlar shape is all....i like my 2041 with the long manifold on my sidewinders, but i will be gettin a 2090 over the winter im sure
#3998
#3999
This exhaust is very cheap in Europe, check www.ebay.de and will give you a lot off performance and very good fuel consumption.
The 2090 pipe is not the Alpha efra 2090 pipe but, the OS 2090 (efra 2089) pipe !!
I myself use only de OS 2090 or the Mielke 2041 on all my OS based engines VZ-B and XZ-B, very similair performance, the OS 2090 gives a little bit more runtime, Mielke 2041 gives the XZB engine more power, but not by much.
#4001
Since you are in Europe, you should have no problems getting your hands on a Mielke/RMV efra 2041 exhaust.
#4003
I actually like the 2090 pipe better on my Bullitt 218 .21 engine (which is exactly the same as the OS Speed) than the 2041 pipe from Reckward. Power delivery is smoother and more linear with the 2090, but with the 2041, the engine has insane top end power and speed. I'll let you know if I decide to finally sell the 2041.
