NEW OS 21 XZ-B and Speed XZ-B
#3961
21 xzb
What are the stock needle settings for the 21 xzb
#3964
You say that as if it's a bad thing... 9% is certainly not a low amount of oil, many custom blends use about half that amount, 4-5%. And as Byron fuels have won so many National and World Championships, I can guarantee, even though I've never used Byron fuels, that it will be perfectly safe to use in any engine commonly available which doesn't have any 'special' or out of the ordinary requirements.
They are one of the most popular fuel manufacturers worldwide, so I know they do a lot of R&D and would never release a fuel that could possibly damage a persons engine.
Just out of curiosity, have you read anywhere something which states the amount of oil a particular OS Speed engine requires? If so, where did you read it and what engine were they referring to? I'm just interested to read the article/story/whatever as I've not come across anyone saying that any specific engine requires a certain minimum % of oil to safely run the engine without damaging it.
You should be safe using just about any brand-name fuel in your engin. BTW, which OS Speed engine are you using?
#3966
OS speed
Usually I ran my old OS speed with a local fuel that one of our store made itself.the local fuel is 25 nitromethane and 12% oil. At the store and some of our local driver said that this is what recommend for this engine.
Now I order the new OS speed the xz-b and there is a problem with the local fuel and I was "need" to choose between buyron to sidewinder.
Some local driver said that the % of the oil is not good for the engine
It will run great for one gallon but not more. The old one that still on my car had 3 gallon and now running the 4.
Asher
#3967
I wouldn't get Byrons fuel without an doubt
#3968
#3969
First, thank you for you answer.
Asher
Asher
#3970
But how is the XZ-B anyway? Is it good for truggy? Is it really big on power? I got put off OS (at least anything non-Speed.., but then I'd never pay for one of those anyway..) several years ago by seeing lots of guys having their VSPEC's blow up(broken con-rods mostly..) I don't race seriously enough - and just don't have the budget frankly, so I'll never be buying a Speed.. But if the right deal came along for the XZ-B, I might give it a go... I know they tune easily, but for me it'd have to be a.) under €200, b.) have big power, and c.) be a solid 8-gallon engine with no absolute need to replace rod or bearings...
#3971
I have a hunch part of the reason they're bringing out this engine is because the blue-head XZ-B just isn't selling.. They're clearly trying to establish the price of the blue-head in Germany at around €225-250, but I regularly see them "on sale" for €199.. Too many other good options available, and hard-core racer OS-fans will take the Speed..
I agree with your points.
For one the blue xz-b head is ugly, it's all notchy and old fashioned.
If you buy a cheap alpha engine you get a nice head. (Lutz or a830)
For €250 you can also get a Novarossi engine. That also has a nice head, and is competitive.
I'm also weery of crank pin wear. As far as I can tell it does not have the DLC coating. I mean, I could be wrong, but that sounds like a disadvantage.
I just happen to think that in this price range the competition is stiff, and O.S. have missed a trick. If it had a more attractive cooling head and the DLC coating then I'm sure more people would buy it.
As far as the old VZ-B blue head, that was a total dud.
For a while it came with bad bearings, which the balls would shatter and shoot metal pieces all around in the engine, and basicly ruin it. I changed mine after 1/2 gallon, and at that stage they had already become all gritty and awful. Very near failure!
Then there was the crank pin wear... it just wasn't a very good engine for me.
#3972
I like the XZ-B head..
#3973
EDIT: I am talking about the engine styling/looks/aesthetics, not the engines performance... just realized it may be interpreted the wrong way.
I agree that the blue head isn't my cup of tea.
One thing is that it's dated. The styling is the same as the .28 XZ, which has been out for years.
#3975
How is it though? Big power? Long lasting? Seen a vid of one in a Mugen trug (in Texas somewhere I think), and it looked pretty good, especially on top..
