Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Clockwork Racing Engines and Products... >
Old 02-15-2013 | 08:46 AM
  #6751
Originally Posted by Maximo
I Am not sure, but I believe it is in the oil.....it works perfectly fine in a stock engine, but is unstable and detonates badly in the modified engines........
Also it is terrible for breakins, you will sit there for a year trying to get the pinch knocked out of a engine.....the synthetics used protect extremely well under lower loads and RPM...which works against breakin...However at high RPM's and loads the oil breaks down and leaves the engine very unprotected.........Nothing wrong with the fuel, but its not suitable for a high RPM, high compression modified race engine.....
That is good to know. I don't even know if it is available here, but I will stay away from it when I get a new engine. Thanks for the info.
pitboss is offline
Old 02-15-2013 | 09:29 AM
  #6752
Maximo's Avatar
If your buying a stock engine then that fuel would probably work fine for you ....The issue is the modified engines we produce here at Clockwork run higher compression as well as RPM so we put higher demands on the fuels... Not only do we require stronger lubrication we also need a strong ability to create a hydraulic seal inside the crankcase, The modified engines run much higher crankcase vacuum and some fuels are unable to properly seal the crankcase.. If the crankcase doesn't seal correctly the engines will not run very well...Its not that anything is bad, its just over the years we have found certain fuels will run much better in the modifieds then other fuels will.....
Maximo is offline
Old 02-15-2013 | 02:48 PM
  #6753
johnatpc's Avatar
Default after run oil
What kind of after run oil do I use in my CRE mills?Is 3 and 1oil ok?Thanks JB.
johnatpc is offline
Old 02-15-2013 | 02:54 PM
  #6754
johnatpc's Avatar
Default headers
Also I `m using the 9886 pipe on the Bonito in a truggy,P5 in a buggy what header do I need to use for each?Thanks again JB.
johnatpc is offline
Old 02-15-2013 | 03:48 PM
  #6755
McD44's Avatar
Neal recommended the 41001 and that's what I bought. I have the P5 and 9886 in my TKI3.
McD44 is offline
Old 02-15-2013 | 04:18 PM
  #6756
hookem34's Avatar
R/C Tech Elite Member
The 9886/41001 is the majic sweet spot for all the Nova CRE engines I own. 2096/41001 is also good, but not as dynamic. 2096/41021 is good, but not great anywhere in the power band...good for those who want a tame CRE Nova (not my preferred style). Werks 2058 is probably my second favorite pipe/header combo.
Neal rang you earlier, but nobody was home. Just checking in on our new baby. Need to grab some fuel and the 41019 header. Maybe a brass Buku as well with heavy Komposite shoes?
Bill I would love to know some of your Kyosho setups. I hear you really lay it down out at Fear Farm. Rob thanks for the Buku spring setting suggestions...gave them a workout recently and really liked the feel. No more low end bog.
hookem34 is offline
Old 02-15-2013 | 04:49 PM
  #6757
xc7's Avatar
xc7
Originally Posted by nickdawg18
What would be a better engine in an mbx7? The keep off 4 keep off 7 or the plus 4 btts?
Clocked BTTS gets my vote. Not from experience or knowledge though. Just appears to be a better choice for buggy.
I'll have to agree also.. Our Clocked BTT 9886SS/41001 is badass but wicked for buggy.
We've got a couple BTTS's arriving soon, hopefully the Keepoff's will be in with that order too
xc7 is offline
Old 02-15-2013 | 06:15 PM
  #6758
Default The new p5
I have to say I am impressed with the p5 I haven't got to really lay into it yet. But so far wow. Awesome.
Ok I have a few question. I have 9 tanks through it. I have a slightly rich tune on it still.
1. I want to go race tmro night with it. I plan on getting there hours befor race time to get some more tanks through it. But do u think it will be ok to put a race day on it now?
2. I got the 086 pipe with my p5 but was wondering I'm running it in truggy
Would I be better off running a 2058 pipe I have instead of the 086.
3. What do y'all think about vp power master 30/9 fuel?
Gsnow39 is offline
Old 02-15-2013 | 07:09 PM
  #6759
rider313's Avatar
#1, get her on the track and start leaning her out tank by tank. Don't go to fast with the leaning.
#2, Wait for Neil's response,
#3, VP-Powermasters is some legit fuel.
rider313 is offline
  #6760
bonesbs's Avatar
Originally Posted by Retired09
Rob. I just ran my MP9 on the road with a BUKU clutch. After about 2 minutes I thought exactly what you are saying. Whatever CRE is doing with this new version of P5 is unbelievable.
I also limited my throttle travel to about 65-70% open area of the 7mm restrictor. No notable difference in a 75-100 yard run. Could only notice it if I wound it out for about 150 yards. I'm thinking I will get better mileage, as on this carb the LSN does not protrude out at these settings, thus limiting fuel flow (probably unwanted fuel flow).
I'm going to try it on the track, as is, and then probably go to the brass flywheel to harness some of this crazy power!!!!!!! I'm loving it!
+ YouTube Video
Bill,
Good luck next week at DNC, as the Clocked P5 looks FAST. I just wish we were racing here in the Midwest instead of cold and gloomy.
bonesbs is offline
Old 02-16-2013 | 06:35 AM
  #6761
hookem34's Avatar
Curious about the Bones fuel. Some feedback is appreciated.
hookem34 is offline
Old 02-16-2013 | 06:59 AM
  #6762
oghobavo's Avatar
Well can we share some of those tension settings with fellow Buk's of Hazards? Lol
oghobavo is offline
Old 02-16-2013 | 09:07 AM
  #6763
hambone's Avatar
Sent you a pm
hambone is offline
Old 02-16-2013 | 09:32 AM
  #6764
bonesbs's Avatar
Hookem34 - Bill Mason (Retired09) we be a good source of info since he runs clocked engines and has been running the feul for a couple months.
bonesbs is offline
Old 02-16-2013 | 10:18 AM
  #6765
Bigcountry7277's Avatar
I would love the buku settings as well please!
Bigcountry7277 is offline
