Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
RcRenew.com engine resizing and epoxy crank re-filling >
Like Tree3Likes
Old 11-29-2012 | 07:40 PM
  #1486
Rcrenew's Avatar
Originally Posted by hookem34
Lance I am sending you my CRE B5 piston/sleeve tomorrow for a pinch. Work your majic brother!
You got it thanks
Rcrenew is offline
Old 11-29-2012 | 07:41 PM
  #1487
Rcrenew's Avatar
Originally Posted by needknees
Shipping off an OS .19 Speed for a pinch and bearing replacement today
Thanks will let you know as soon as it arrives
Rcrenew is offline
Old 12-01-2012 | 05:49 AM
  #1488
Rcrenew's Avatar
Dan you B5 P/S set arrived yesterday and was serviced and shipped back out today. Everything looked great so now its resized and you are good to go.
TRacking was e-mailed to you
Thanks again,
Lance
Rcrenew is offline
Old 12-01-2012 | 06:00 AM
  #1489
hookem34's Avatar
R/C Tech Elite Member
Thanks again,
Lance
Man you are all over it! Thanks Lance! Was she pretty loose?
hookem34 is offline
Old 12-03-2012 | 05:59 PM
  #1490
losi68's Avatar
This past weekend at flowood ms . Was awsome 32 car field in pro class was settin 14th .Alpha A830 was awsome all weekend !!!! Never messed a beat...but the throttle return spring broke at the start of the B main put me out.....Big ups to you Lance for such Awsome motors brother...Thanks
losi68 is offline
Old 12-04-2012 | 02:34 AM
  #1491
Guest
Default flowood toys for tots race
lance i ran the luts for the first time with the 0801 pipe, lots of power with that setup. i was in the b main with mark, started the race got in a mess at the begining. but on lap 20 i was able to make it 3rd place and then a corner mashall put a car on the track facing the wrong way on a landing ramp and i hit him head on an broke the shock end. the lutz was very powerful at a fat tune.
LOSIRACER77 is offline
Old 12-04-2012 | 09:05 AM
  #1492
Rcrenew's Avatar
Awesome guys thanks for the update.
Rcrenew is offline
Old 12-05-2012 | 02:03 PM
  #1493
Rcrenew's Avatar
Glenn, Thomas, Samuel and Dan Your Resizing orders were received and have shipped out. Tracking has been emailed.
Thanks guys,
Lance
Rcrenew is offline
Old 12-05-2012 | 04:17 PM
  #1494
Thanks! Can't wait to break that .19 in and run it again. Great engine.
Notice anything strange when you had it apart?
needknees is offline
Old 12-06-2012 | 08:30 PM
  #1495
Rcrenew's Avatar
Hi Dan yes very loose, Took a little work to get a good fitting taper down low on the sleeve. But she's all better now
Thanks again
Rcrenew is offline
Old 12-06-2012 | 08:32 PM
  #1496
Rcrenew's Avatar
No just worn out but no damage, so It turned out great. Just do a normal break in like you would a new engine and it will last a long time.
Rcrenew is offline
Old 12-10-2012 | 01:13 PM
  #1497
Lance,
The .19 showed up today, thank you for your prompt service and shipping! I'll be able to break it in soon in a relatively warm environment, hope to get enough fuel through it to run it this weekend. Only thing I am worried about is the temps this coming weekend will be fairly cold (~35F). Any tips on cold weather running other than fattening the tune up to compensate for the denser air? I don't want to damage this recently serviced .19.
I have another engine I can run that's in its prime, probably should leave that in for these cold winter series races...
Old 12-10-2012 | 01:43 PM
  #1498
Rcrenew's Avatar
Lance,
No problem thank you
Just pre heat it before you start it and try to help it keep warm. ( leave comp heater on it or a sock or something for a few tanks) Thats about it. Keep it on the rich side until it breaks in and loosens up a bit.
Thanks,
Lance
Rcrenew is offline
Old 12-11-2012 | 10:15 AM
  #1499
Got 5 tanks through the .19 last night and it's running great! Can't wait to get a little more fuel through it before the races this Sunday
Definitely will be sending in my VZ-B for a pinch and bearings when it starts to get tired.
Old 12-14-2012 | 06:53 AM
  #1500
Rcrenew's Avatar
Nice
All orders received this wednesday have been serviced and shipped out. Check your e-mail for tracking.
Thanks guys,
Lance
Rcrenew is offline
