Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
RcRenew.com engine resizing and epoxy crank re-filling >
Like Tree3Likes
Old 05-14-2019, 07:19 AM
  #2086
Rcrenew's Avatar
Originally Posted by sebtarta View Post
Morning, is it necessary to add a shim between the front bearing and the cone? I have never done this, but I have read and been told it helps the race of the front bearing when the cone is not on it. If so, do we have a measurement or part # for this shim?
Thanks,
You can add a shim if you need to adjust the offset of your flywheel but it is not required. Also if you do add a shim it needs to fit the crank perfectly and not be larger than the inner race. I have seen many times people use large thin shims and they get bent back ( towards the bearing ) and eat up the bearing seal.
Rcrenew is offline
Old 05-15-2019, 05:02 PM
  #2087
Default Will you accept?
hey lance,
wrote you you a message here about my B5 recently that I had wanted to send to you to get rebuilt. Wanted to know if you would mind if I sent it to you in pieces? Iíll explain..... I donít disassemble my engine often, and want to get a repetition in doing that. So before I deploy, I wanna strip it totally down, inspect it, and learn a little more about the inner workings of a nitro engine. Would you have a problem with me doing that, and sending it to you completely disassembled to get worked on? Just curious.
xlrsd is offline
Old 05-16-2019, 04:55 AM
  #2088
Thank you so much for the info. No shim it is then!
sebtarta is offline
Old 05-16-2019, 05:25 AM
  #2089
Rcrenew's Avatar
Originally Posted by xlrsd View Post
hey lance,
That's no problem go ahead and send it in and I will take a look.
Rcrenew is offline
Old 12-20-2019, 12:04 PM
  #2090
Rcrenew's Avatar
RCR sleeve tools back in stock!
Rcrenew is offline
Old 12-20-2019, 12:06 PM
  #2091
Rcrenew's Avatar
RC engine modifications at 2 day turnaround
Rcrenew is offline
Old 01-08-2020, 10:24 AM
  #2092
blktransam's Avatar
Trader Rating: 59 (100%+)
love my rcrenew sleeve tool and ARO Lance knows his stuff
blktransam is offline
