PICCO .21 BOOST
Old 08-07-2010 | 08:55 AM
  #136
Maximo's Avatar
Originally Posted by toofast55
so for a buggy and looking for good useable smooth power and real good fuel mileage would you suggest the boost or evo3 or what
boost for Buggy !
Maximo is offline
Old 08-07-2010 | 12:05 PM
  #137
Marcus Falconie's Avatar
Originally Posted by Maximo
no the LRP is just a re badged EVO 4, the boost is a updated P3R
I can see the LRP has a P3R block not a EVO 4 block "look close", I think it is a mix of Picco engines.
Marcus Falconie is offline
Old 08-07-2010 | 01:29 PM
  #138
Maximo's Avatar
Your right ! looks alot like a jammin case as well.... The EVO 4 has the newer case with the exhaust spring mounts on the side....I often am too busy looking into the internals that I often don't pay much attention to the case.
Maximo is offline
Old 08-07-2010 | 10:58 PM
  #139
blade954's Avatar
When are you expecting the Boost Neil....
blade954 is offline
Old 08-07-2010 | 11:06 PM
  #140
Maximo's Avatar
they are in stock right now, planning to drop the clock on them mid next week !
Maximo is offline
Old 08-15-2010 | 03:54 AM
  #141
blade954's Avatar
Our Boost just keeps on getting better and better every tank. This is a great mill i was a 1 eye OS engine user but now am loving the Picco range they tune a little different but half the price of the Speed......Great power and run time as well....
blade954 is offline
Old 08-15-2010 | 10:06 AM
  #142
ScottyM's Avatar
What kinda of run time are you seeing? I realize it changes from track to track, and weather coniditions, but an average??
ScottyM is offline
Old 08-15-2010 | 03:51 PM
  #143
blade954's Avatar
We are getting better run times every tank this mill even after 3ltrs when cold will still mechanical pinch at TDC. Normally our OS mills are just hitting the sweet spot...lol, When warm this mill has such a smooth pop you have too feel it for your self. like you said we run it at different tracks and found mixed results as well we have run 10mi run times and had more in the tank and we have run 9mins as well with just vapors in the tank. I think once this thing beads in we should see constant 10min (or very close) run times. Picco has you by the balls so to speak with the way they match there header and pipes together you can not use a OS 2060 on a Picco header but im looking at running a heavy spring through the header pipe and bend one into shape to see if we can get more out of the Picco Boost. All our driving we have run the 6mm insert maybe with the 7mm you might not have to have in nailed as much. next club day i am going to the 7mm and see what we get.
blade954 is offline
Old 08-16-2010 | 12:14 AM
  #144
blade954's Avatar
Any one tryed playing with the shim and changed the port timing yet I have mine apart just wanted to see what the inside looks like, Very impressed with the bearing quality they just seam super smooth.... Going to leave the shim out and try it again see how it works....
blade954 is offline
Old 08-24-2010 | 08:27 PM
  #145
ttt
arm2storm is offline
Old 08-24-2010 | 08:56 PM
  #146
HOw is the Boost for Truggy? I have a O'Donell Z01T
I saw it at
http://www.rc-toro.com/product_info....ed659762b32ae9
enought torque?
silverM3 is offline
Old 08-24-2010 | 10:55 PM
  #147
blade954's Avatar
Most good online shops have them Amain has them listed as well now. I would say more of a Buggy engine but i have seen it in Truggys and still does the job. We have a good 5lrs in ours now and just coming to life. I purchased the Evo 4 5 port for the Truggy with the 2046 long header and it propels the XT8 just nice. The boost does lack some top end but makes up for it on the bottom.
blade954 is offline
Old 08-25-2010 | 10:56 PM
  #148
I noticed that too top end limited alittle almost feels like the EVO 2 engine I have.
pdmustgt is offline
Old 08-26-2010 | 01:59 AM
  #149
blade954's Avatar
Has any one tryed removing the head shim under the sleeve i have but haven't run it yet. I have also found the Boost prefers 25% nitro with the standard head shims....
blade954 is offline
Old 08-26-2010 | 02:47 AM
  #150
savagesam's Avatar
Default reply
Well 4 lts through the engine and gave it a run this week end in the d8t truggy with the 6mm venturi installed, nice clean power from start to top end, runs out of legs at about 35 mitres down a long straight running 13/50 in the d8t ...... got through 4 heats ( 10 minutes each ) with out a pit stop but will admit it was running on fummes when i did the extra lap and the engine temps where around the 130 mark when i came in ......
My jammin 21 plus engine runs rings around it for power and run time but for the price and the smooth power supply its a handy spare engine for now.
Think it would be an awsome engine for a buggy thats for sure.....
savagesam is offline
