TQ Engines
Old 11-01-2010 | 08:22 AM
  #421
RoyJ's Avatar
Default TQ Engine Break-In Cautionary Tips
Be mindful that with high-compression Italian motors, you must take your time during the full break-in period of 1-1.5 gallons. Know that running-in these engines is the preliminary period prior to break-in. With an OS engine you can run-in a few tanks, and then race it without much concern. Not with these!
Otherwise you could experience premature connecting rod wear or failure. The most common sign of rod wear is the sudden case of blowing plugs repeatedly.
The TQ rod has an oil hole for the crankpin in the lower bushing, like most others. However, at the exit of the TQ oil hole inside the bushing, it is elongated for maximum oil flow. The drawback to that design is that the bushing is vulerable to over-rev damage when the fit of the engine is still extremely tight. So please be careful not to over-rev your new TQ engine while in it's full break-in period, especially if you flip upside down and try to get the attention of a marshal. We've all done it.
If you take your time and not race your TQ engine prior to full break-in, the engine's P/S/R will last a very long time, perhaps the entire season of weekly racing. However, if you race your TQ engine prior to fully breaking in, you will be advised to change the rod after 1-1.5 gallons, to maximize the life of your P/S.
Also, if you will be running 30% nitro, go ahead and add the extra 0.1 shim. This will help relieve some of the pressure on your new TQ mill, increasing cooling and mileage.
RoyJ is offline
Old 11-03-2010 | 10:36 AM
  #422
allaboutwho02's Avatar
Im thinking of getting this engine. What glow plug do you recomend? P3, P4, P6 or any thing else better? Also will the GRP pipe work fine with this engine? You know the origianl one for the GRP motor. Does the motor needed sealed at all?
allaboutwho02 is offline
Old 11-03-2010 | 10:59 AM
  #423
TQ plugs. H4/5/6 based on outside temps... But 99% of the time I ran h6 plug. I've used the 2069 and 2053. 2069 makes a tad more power. Fuel mileage is a little better too. If you can I would definately recommend the 2069 pipe. No sealing on the motor, was not needed.
underway is offline
Old 11-03-2010 | 03:29 PM
  #424
pyromania's Avatar
Don't use OS plugs with this engine. I personally use TQ's H5 for almost all conditions.
As for pipes, the GRP 2053 will work really well with the TQ mill. Another pipe you may want to try is OS 2060 or Losi's RE-10.
Ha I found the list:
Originally Posted by RoyJ
Actually Technopower does not list our complete plug selection, which is as follows:
H4T = very hot
H5T = hot
H6T = medium (stock plug)
H7T = cold
pyromania is offline
Old 11-03-2010 | 05:30 PM
  #425
houston's Avatar
excellent advice
houston is offline
Old 11-03-2010 | 05:40 PM
  #426
Cool sounds good guys. I have the grp and ninja grp based 2053 pipes. Along with the os 2060. What kind of mileage do you guys get? Anymore info on this engine that would be helpful?
Old 11-03-2010 | 06:25 PM
  #427
pyromania's Avatar
I use the OS 2060 pipe with my mill. In Truggy, 12 min easy. In buggy right on the edge of 10min with a semi-rich tune.
Old 11-16-2010 | 05:13 PM
  #428
pyromania's Avatar
If any of you guys are looking for a .28 GRP rod, the TQ rod will work. I just found the GRP manual and the rods are the same between the .21 and .28.
Old 11-18-2010 | 03:13 PM
  #429
RoyJ's Avatar
Default News
New TQ engine parts are now in-stock.
Also, TQ is working on a revision for 2011, so stay tuned.
RoyJ is offline
Old 11-19-2010 | 07:31 AM
  #430
Toiffel's Avatar
Are the TQ plugs similar or the same as the GRP plugs??
Toiffel is offline
Old 11-19-2010 | 07:49 AM
  #431
RoyJ's Avatar
Yes.
RoyJ is offline
Old 11-23-2010 | 02:02 AM
  #432
Picked up a TQ engine and I've got to say, this thing looks great. Unfortunately, it'll be a while before I can use it.
RoyJ- good info you've provided. I did that with a Jammin I had a couple years back, and it turned out to be an incredibly reliable engine.
K.Copeland is offline
Old 11-25-2010 | 08:44 AM
  #433
b-man777's Avatar
Hey all: Just curious how close are the new TQ engines to the ones GRP/Losi were offering? Thanks
b-man777 is offline
Old 12-01-2010 | 12:43 PM
  #434
Default Very Silmilar
The engines are very similar in design and performance.TQ improved on the car and the connecting rod.
These motors are selling for 175.00 right now and that's a steal
topfuelhobbies is offline
Old 12-01-2010 | 02:20 PM
  #435
GSFan's Avatar
Where can I get one at that price?
GSFan is offline
