Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
TecnoPower Engine Thread ( From Rody Roem ) >
Old 07-28-2011 | 08:20 PM
  #526
vypr2002's Avatar
quick question for those that run the .23
What pipe are you all running? And what fuel % are you using?
I run 40% at 5500ft here in Colorado and am running the shims it came with.
I have no detonation and the motor has a little over 2 gallons on it. No issues but want to get the correct pipe for it.
vypr2002 is offline
Old 08-01-2011 | 03:41 PM
  #527
Just came back from the Region 4 ROAR Off Road Fuel Championship race in Spokane Washington. B03 and T02 performed flawlessly. In the the truggy A Main I was the only driver to do 10 minute pit stops!!!! I was able to finish in the 3rd spot after giving 2nd away!!!
In buggy my B03 was not quite as broken in as my T02 so I wasn't quite as confident about doing the 10 minute pit stops even though I could have with ease as I was finishing a 8 minute qualifing run with a 1/3 tank of fuel left!!! I finished in the 3rd spot in buggy as well.
Even though both engines were still new and tight, no one could pull me down the straight aways or infield and NO ONE was getting the run time I was. These engines are absolutely AWESOME!!!
Next weekend is Round 2 of the Canadian Off Road Championship Series at my home track, looking forward to see how they perform there!!
SupermaxxRich is offline
Old 08-02-2011 | 06:43 AM
  #528
TecnoPower's Avatar
Originally Posted by aznitronut
What is the difference from what came with the engine?
This combustion chamber has less volume compared to the original one. It is like using less shims but less dangerous because the button does not come too close to the piston at TDC in this way.
This will change the engine behaviour more then just changing the backplate.
TecnoPower is offline
Old 08-02-2011 | 06:45 AM
  #529
TecnoPower's Avatar
With the .23 you can use the same pipes you are using with the .21, there is no real need to use a special pipe for this.
Running at high altitude might make you try the V1 combustion chamber, you will gain torque...
Old 08-02-2011 | 07:39 AM
  #530
aznitronut's Avatar
Okay, thanks.
aznitronut is offline
Old 08-02-2011 | 10:42 PM
  #531
RCworks216's Avatar
amain must have a typo.........$290 for a P/S/R??? the motor is $230... is that price right???
RCworks216 is offline
Old 08-03-2011 | 06:16 AM
  #532
Default bo3
For those who owns b03 how much does it weigh (just the engine no filter no ingine mount no clucth no pipe) Iknow the pecs says 335g. Isthis correct? If so that would make it the lightest engine in the market with good power.
tracktearer is offline
Old 08-03-2011 | 11:07 AM
  #533
That is correct. I weighed mine as soon as I got it and it is indeed 335 grams AWESOME ENGINE!!!! Not only light, powerful but really lowers the centre of gravity
Old 08-03-2011 | 11:51 AM
  #534
thank sfor quick reply
Old 08-07-2011 | 10:38 PM
  #535
This weekend was Round 2 of the CORCS (Canadian Off Road Championship Series) and did my Tecnopower engines impress the hell out of EVERYONE!!!! Not only were the engines making great power but on this very loose and bumpy track I was the only driver in both 1/8 Buggy and 1/8 Truggy to pull off 10 minute pit stops in the main!!!
Ultra smooth power out of both engines, reliability and a idle that would go all day long!!!! I really can't say enough about these engines. Definitely worth giving them a try if your in the market for a new engines. And I highly recommend a P4 plug
Here are some pics of my cars just before the race
Old 08-08-2011 | 03:44 AM
  #536
vti-chris's Avatar
anyone used an OS carb on the .21b? I have one of the first models and when is hot...it flameouts and then needs about 5 minutes to restart.
vti-chris is offline
Old 08-08-2011 | 03:52 AM
  #537
That sounds like the piston and sleeve are do. No compression
At temps.
janderson78 is offline
Old 08-08-2011 | 07:08 AM
  #538
vti-chris's Avatar
it does seem to hzve low compresion but it did work in the winter running at the same temps.
Old 08-08-2011 | 07:49 AM
  #539
aznitronut's Avatar
For 20.00 USD you can send it to RcRenew.com have it pinched.
Old 08-08-2011 | 02:18 PM
  #540
bigjay5's Avatar
Thumbs up
Hi Richard, very nice indeed. Just got a B03 myself for Buggy with the 2034 pipe and the speed header - just sitting there waiting for run in. Interesting to see the model number of the engine in your Truggy appears to be blanked out - you testing a prototype model? Is it a 0.21 or a 0.23? Has anyone tried the B03 in Truggy? I haven't even run the B03 yet and I'm already thinking about another TP for my Truggy...........
bigjay5 is offline
