Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
TecnoPower Engine Thread ( From Rody Roem ) >
Old 01-22-2012 | 07:10 AM
  #676
Originally Posted by revsinc
yes i have, its lacks mid and top end power ,
switch to the 2069 and it was astonishing the difference
so much more power and still great fuel economy ..
dont waste your time with a grp pipe, in fact find a hammer and beat
that pipe to pulp ...
ok thanks,
tracktearer is offline
Old 01-22-2012 | 07:22 AM
  #677
Originally Posted by Ambros303
Seems like REDS is using the 2034 and 2069 HIPEX pipes aswell.
They list the 2069 as the performance pipe and the 2034 as the more fuel efficient pipe.
Would it be safe to say the 2034 is a low end pipe and the 2069 a top end pipe?
Btw, since REDS is Picco made it is a good possibility these pipes are good on Picco engines aswell.
i thought read somewhere 2069 is low end pipe, 2034 mid/ high end pipe.
my local track is medium size/traction mix of long straight, sweeping/tight/off camber turns, medium jumps.
anyway maybe i should get both pipes. thanks
Old 01-22-2012 | 09:04 AM
  #678
aznitronut's Avatar
Just looked at the web site for parts listing, I was looking at a new under head button for the 1st edition B01 Tecnopower .21 engine. The price is showing part number 0102001-V1, priced at 16,75 €, about $21.64 USD, with shipping and handling it would cost me about, $52.65. Twice as much as the part??? Is the correct pricing?
aznitronut is offline
Old 01-22-2012 | 09:45 AM
  #679
Jaz240's Avatar
Tony, I have a Technopower account. That part is not listed on the USA distributors website. See if the 102002 will fit. Its on clearance
Jaz240 is offline
Old 01-22-2012 | 10:01 AM
  #680
aznitronut's Avatar
It will fit, but, its the same thing that is already on there. This is the post I got from them awhile back for better improvement from original.
I think you will obtain better results with the V1 combustion chamber part#0102001-V1 it comes with a H6 turbo glowplug
On the B01 I suggest you try this chamber with 0.3mm of headshims and 25-30% nitrofuel.
Old 01-22-2012 | 04:49 PM
  #681
its good for high elivation. but with regular button u can just reduce the shimming.
Old 01-23-2012 | 04:29 AM
  #682
revsinc's Avatar
Originally Posted by motomatt
This came up on my facebook page.
Here's your chance to stock up om spares.
http://www.tecnopower-motor.com/OUTLET/en/
i want to order some parts , but my country does not appear on the address list
oh well .
revsinc is offline
Old 01-23-2012 | 11:14 AM
  #683
aznitronut's Avatar
What are the stock carb settings for the BO1?
Old 01-23-2012 | 11:42 AM
  #684
motomatt's Avatar
http://www.tecnopower-motor.com/imag.../01001-21b.pdf
motomatt is offline
Old 01-23-2012 | 11:55 AM
  #685
aznitronut's Avatar
Old 02-24-2012 | 04:25 PM
  #686
Anybody know where I can find a rod for the .23 engine? Or if another manufacturer's rod will work in this engine?
nick64merc is offline
Old 02-24-2012 | 11:18 PM
  #687
TecnoPower's Avatar
http://www.tecnopower-motor.com/OUTL...h_query=conrod
TecnoPower is offline
Old 02-25-2012 | 04:37 AM
  #688
Default b03 vs b04t
hi rody. whats is the difference between the b03 and b04t performance, characteristic, and milage? thanks.
Old 02-25-2012 | 09:28 AM
  #689
TecnoPower's Avatar
The B04T has the same performance as the B03 basically the engines are the same, I cannot build more B03 engines because I have run out of cooling-heads, so we use the Light version of the B02T and I also am using the same crankshaft as the B02T inside this engine which has the IBOND hardcoating.
Milage is about the same as the B03 but this depends also a lot on your driving style and car efficiency.
Old 02-26-2012 | 05:49 AM
  #690
i sent you a pm.
