Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
TecnoPower Engine Thread ( From Rody Roem ) >
Old 01-28-2011 | 08:08 PM
  #421
aznitronut's Avatar
Yea, I run an RB WS7 III, 2045/ 192, on big tracks, like The Nitro Pit, on shorter tracks, I go with the 198 header, it really gives that 7 port some bottom. I was just wondering if the 198 header will be to much bottom on the tecnopower 5 port. I going to useit in a Losi truggy 2.0. Depending on power band, I can go with different clutch shoes2 slum, 2 carbon. At times I switch engines over to a C6, it gets 10 plus minutes on tank of fuel, if I use a 6.5 resrtictor in the tecnopower will it improve the fuel much more? Has anyone tried the 6.5 in the Tecnopower?
aznitronut is offline
Old 01-29-2011 | 07:40 PM
  #422
aznitronut's Avatar
How much difference is there between the BO1 & BO1T? Run time? Performance?
Old 01-30-2011 | 08:57 AM
  #423
motomatt's Avatar
post #380
Originally Posted by J.Whiting
well i got a very good chance to run the bo1 and to1
bo1 was good all day finally broke in at the 2 gallon mark.... motor temps where 200-210 all day.. was consistant 10.30 to with a 7mm restrictor in buggy.. odonnell fuel.. 1.1 clutch ( which a 1.0 will be put in for next race) with aluminum 3 shoe clutch.. very smooth nice usable power band no complaints here on this motor...
to1 was good all day but still has a bit to go before it gets broke in.. have around 1.5 gallons on it and still has crazy pinch.. even without the plug in it will stop by the pinch... was geting 11 mins easy with a tad left in the tank in the truggy.. motor temps never seen over 200* all day.. crazy crazy power out of this mill... we had this 1 jump right off a corner and the buggys could just make it.. very few truggy where making it but i had no problems all day with it... qualified 4th in the "a' and we took off.. got to the lead by lap 3.. started to pull away from the pack and yup around lap 10-11 the worst thing possible happend.. a lapped car missed a jump and landed in the straightaway... well going full wood down the straight i hit him head on.. ripped the hole left side of the truck off.. left front arm, left rear arm, exhaust got removed and wing broke... and ya know the kicker... that truck drove away from the blast..... thank to tony and rody for thess great engines... got alot of questions on the motors.. this will be the must have engine in truggy this summer.. the best of the best in my eyes.. bottom of a .25-.28 and the rpm's of the .21's.. this motor is hands down better than the c6 he made years ago... thank you again.. jeremy
motomatt is offline
Old 01-30-2011 | 09:34 AM
  #424
aznitronut's Avatar
motomatt, Thanks
Old 02-02-2011 | 11:30 AM
  #425
Has anybody tried the 2069 or 2034 pipes on any other engines with success?
NitroVein is offline
Old 02-02-2011 | 01:27 PM
  #426
I got about a min longer with the tuned version over the standard
johnperdeye is offline
Old 02-03-2011 | 02:58 PM
  #427
Simple GREEN's Avatar
dose anyone know a street price on the new technopower engines ( BO3 BO2 BO2T)
and when they will be available on a-main and the sort.
Simple GREEN is offline
Old 02-03-2011 | 05:36 PM
  #428
mayhem04's Avatar
I dont know if Amain is going to carry anymore of the technopowers
mayhem04 is offline
Old 02-11-2011 | 03:59 PM
  #429
RCworks216's Avatar
Wondering if anyone has used other plugs than the TP h6 or h7? i understand that TP plug are hotter than hot so should i just use ultra hot or the hottiest plug my LHS has?
RCworks216 is offline
Old 02-11-2011 | 06:31 PM
  #430
Funking-Awesome's Avatar
I use OS P4's. Don't forget though I'm in Australia so the weather is a bit warmer here. Once the winter season arrives I may need to run a hotter plug to compensate for the cooler weather. But once again, the coldest I have ever raced in is about 15 degrees Celsius.
Funking-Awesome is offline
Old 02-11-2011 | 06:55 PM
  #431
RCworks216's Avatar
Ok thanks. I have some p3's ill try.
Old 02-21-2011 | 05:03 PM
  #432
PhillyDees's Avatar
Default Tecno Power
Where can we buy the BO3 Head? I want to put it on my BO1! Thanks
PhillyDees is offline
Old 02-22-2011 | 12:21 AM
  #433
TecnoPower's Avatar
Part#0101001-BLG, however this head does not fit on the square shaped crankcase of the B01 type engines sorry.
For where to buy, we are having contact with a distributor who will try to get all the TECNOPOWER products available through Amain in the USA.
TecnoPower is offline
Old 02-22-2011 | 12:49 AM
  #434
PhillyDees's Avatar
Default Thanks
Will we even be able to get the BO3's? And when?
Old 02-22-2011 | 03:29 AM
  #435
TecnoPower's Avatar
Normallly yes, please try and call or e-mail with Amain for availability. The B03 should become available end of march if all goes well.
B02 and B02T are available in small qty's.
