pipe cleaning
#31
i have been use degreaser liquid soap...my result is pipe look shine..
#32
ok guys so the experiment is over. i went to walmart last night and bought a small 2qt crock pot for $10 and 100% anitfreeze (not the poremixed 50/50) i put the pipe in the crock pot on high about 10pm, checked it about 8am this morning and the thing was absolutely SPOTLESS. worked like a charm
#34
I didnt read the whole thread, but in case noone has brought this up yet... I use Monster Mudd Wash. It's biodegradeable, yet quite potent. I dilute it 3 parts water to 1 part wash for cleaning metal parts- just disassemble your exhaust (remove all springs and seals), and let is soak overnight. Then, just wipe it off with a wet cloth. You can also use it at full strength to remove aluminum anodizing. Or, just mix 5 parts water to 1 part wash for general RC car cleaning, then follow up with water and compressed air and use your fav silicon spray to keep things clean.
Best of all, a gallon will only set you back 10 bucks:
http://www.northerntool.com/shop/too...4805_200324805
I've used this stuff for my motocross bikes for a while, and it works like a champ.
#36
Where you get the anti freeze at walmart too? And do u fill the crock pot to the top? I wanna try this haha
#37
i bought the anitfreeze at walmart too. i got the 100% not the 50/50 mix. i didnt fill it to the top only till it covered the pipe. i dont think that really matters but the pipe doesnt float so i just think it would be a waste to fill to the top. try it out you will be so SURPRISED
#38
#39
You only need enoug Anit-freeze to cover pipes.. I put the pipes in the pot, and then filled the pot just about 1/4" above the highest pipe. Even if some evaporation happens you won't uncover your pipe.. Make sense?? You can get Anti-freeze at walmart or any place that sells auto parts..
#40
I got the pot and antifreeze and am giving this a go right now, thanks all
#44
I have to say the results are amazing! The pipe and manifold came out like new. The crock pot was too small (the $10.88 one at walmart) cause pipe was sticking out the top so I couldn't fully submerge it had to flip it over half way through.. there was a bit bigger one for 5 bucks more oh well haha 10th scale pipes should have no problem. I actually did it in the kitchen I didn't notice any odor around the house unless I was standing over the pot I had the lid on the entire time
#45
