Like Tree4Likes
COMPETITION HEAT INC.
Old 04-01-2016 | 06:28 PM
  #1906
Nat Maniac's Avatar
Can anyone in Australia recommend a transformer to use with the 120v AC version?
Also can anyone confirm how many watts it requires or how many amps it draws?
It's the deuce 2.
There is a 50 watt transformer at the local hobby shop I'm just not sure if that's enough..
Thanks!
Nat Maniac is offline
Old 10-22-2016 | 08:27 PM
  #1907
wrenchdoctor's Avatar
Anyone had success fixing these? I purchased one from amain back in April and it stopped working today at the track.
wrenchdoctor is offline
Old 10-22-2016 | 08:58 PM
  #1908
grizz1's Avatar
Best idea is to pick up a replacement element from A-Main. Be either the element itself or where the wires enter the element. Be careful not to pull the heater off the cooling head by the wires. These units are generally really reliable and carry on happily heating for a couple of years easy.
grizz1 is offline
Old 11-04-2016 | 09:28 AM
  #1909
Zerodefect's Avatar
It's the deuce 2.
Thanks!
W=VA
V=IR
Can anyone clamp the wires to see how many amps this thing pulls? Or use a meter to measure how much resistance the coil has? Then it's simple math to find out how many watts it pulls.
I believe the battery warmers I sell are only 50 watts. So I'd imagine that 50 should do, but not sure.
Zerodefect is offline
Old 04-19-2017 | 02:53 PM
  #1910
Cappy's Avatar
Am i risking burning up my new heater running it at 12.3v ? I bought this thinking that ill be able to use my power supply but the lowest V it will put out is 12.3
Cappy is offline
Old 04-20-2017 | 09:20 AM
  #1911
Jerm13's Avatar
No. A fully charged 3s is 12.6V and works just fine. I have used and seen 16-17V (4s) just fine as well. But I have also seen them go up in glorious flames at 20V
Keep it below 15ish just to be on the safe side.
Cappy likes this.
Jerm13 is offline
Old 04-20-2017 | 06:01 PM
  #1912
beidle99's Avatar
You do know these are not for Ebuggy right.
Cappy likes this.
beidle99 is offline
Old 04-21-2017 | 02:23 AM
  #1913
Cappy's Avatar
Says you !!
When you comin back ?
Cappy is offline
Old 02-20-2018 | 03:00 PM
  #1914
daveflyr's Avatar
Does anyone know the whereabouts of Eric Wise these days? He is not responding to his emails, the last time I was able to get through to him was last September!
daveflyr is offline
Old 02-26-2018 | 01:48 PM
  #1915
token's Avatar
Nope - tried to order stuff from the website and go no response. Just had to order a different brand. Hope everything is ok with dude.
token is offline
Old 10-28-2018 | 11:27 AM
  #1916
invrtd's Avatar
Are these guys still in business?
invrtd is offline
Old 01-15-2019 | 08:43 PM
  #1917
Default ??
Where can you buy these anymore?
Iggy 102 is offline
Old 01-17-2019 | 05:37 PM
  #1918
Morpheus1289's Avatar
^^^ I just got one off eBay recently very cheap, less than $20 new. Despite being “modified” (I cut it in certain areas) it does not fit my B2102 very well. I wish more companies made heaters to fit low profile cooling heads. The only company I know that does is in Europe and I’m not sure if they are around anymore.
Morpheus1289 is offline
Old 01-20-2019 | 07:25 PM
  #1919
daveflyr's Avatar
Morpheus1289, after competition heat disappeared I chose to buy a nitro engine head warmer from IB-prostart in England. Good quality, although it doesn't get as hot as the competition heat did, but maybe that's why the element on the Competition heat burnt out. Shipping took less than two weeks to Canada. If you check out ibprostart.com you will find they have a low profile heater that I believe fits your b2102, there is a picture of Ty Tessmann's buggy with a IB prostart on the head.
Morpheus1289 likes this.
daveflyr is offline
Old 06-14-2019 | 10:53 AM
  #1920
Default 120v Comp Heat engine heaters
Anyone interested or looking for the Comp Heat engine heaters (120v) can PM me. I have a few left over.
CompHeat is offline
