COMPETITION HEAT INC.
#1891
#1892
Does anyone know what type of glue/adhesive that Comp Heat uses or can be used for sticking the heating element to the fabric cover?
I thought the element had burned out and was removing it before ordering a new one, but discovered one of the wires broke right where it enters the heating element. A bit of careful soldering fixed it, but not sure how to get it to stick again in the cover.
Any help is much appreciated.
#1895
Is there a replacement sock for these? I have the competition d/c but I bought a off brand a/c and it cooked the sock to nothing. Hate to have to buy a whole new one but if I have to I guess it could be worse.
#1896
#1899
I've 4000 mAh and it does its job ok. If I should buy a new battery I would go for 5000 or more.
Normally I use an old power supply from a PC. You'll need 12DC (12,6 volt MAX!) and at least 10 Ah in a power supply.
#1900
This place is really quiet but I might as well voice my opinion .I purchased a competition heat for use in racing and to ease engine break in. For the first month I had it I loved it, it was the best thing since sliced bread. I always was careful of the wire coming off the heating mat because the mfg says be careful so I was. I never pulled on the wires and I always stored it in the box. Not really sure what happened.I tried contactingt he manufacture through email with no luck so now I have a heater that serves no purpose since it is not working. Any ideas how to contact the manufacturer
#1903
Please shoot me another email (eric @compracingproducts.com) it probably came in as spam.
#1905
Can anyone in Australia recommend a transformer to use with the 120v AC version?
Also can anyone confirm how many watts it requires or how many amps it draws?
It's the deuce 2.
There is a 50 watt transformer at the local hobby shop I'm just not sure if that's enough..
Thanks!
It's the deuce 2.
Thanks!
4Likes
