AXE ROSSI Engine thread.....
#361
o-rings
http://www.mcmaster.com/#o-rings/=bksjru
Silicone Type
Standard: Has excellent resistance to ozone, weather, detergent, and salt water. Also has good high and low temperature resistance.
FEP-Encapsulated: Perfect for sealing corrosive fluids, an FEP encapsulation makes these O-rings virtually impervious to most solvents and chemicals. Excellent resistance to friction and compression makes them ideal for static sealing applications. The FEP encapsulation meets ASTM D2116 and LP389A and is FDA compliant. Durometer hardness is A85 and temperature range is -75° to 400°F. O-rings are clear with a red-orange inner ring.
FDA Compliant: The FDA-compliant material used to make these o-rings makes them safe for food contact.
Soft: Durometer hardness is A50. Excellent ozone, weather, detergent, and salt water resistance. Good high and low temperature resistance.
Silicone Type
#362
Pipes
I have persisted with my axe .25 cobra motors despite the rods being a problem. Finally sorted the rod issue out by useing a GO PRO rod for about $23, the R7 NOVA rod works as well but the GO is less than half the price. Latest engine has got about 30litres (7-8gallons) on it with the rod being changed at the 5litre mark and it is still in great nick.
I have tried a few pipes on these engines and finally settled on the JP4, that was until I tried the GO 2072 pipe on it. The pipe really showed the true potential of this engine. Still has stump pulling low but now it pulls that hard all the way through to a screaming top with about 1 1/2 minutes extra run time. This pipe will not be coming of this motor any time soon.
Go the axe (with a better rod) you wont look back.
#363
axe engine
yea there was a problem with the rods for sure the x2 that i been running has got there new rod i got 7 gallons before i had an issue with the rod and thats hard racing on it but its good to know what other rods work can upost part numbers to rod that you found to work. and now iam running a mamba with the jp2 which works very well and good run time
#364
Axe Rossi USA
Anybody know what is going on with Axe Rossi USA? No replies to my emails and the inventory list on the website is getting smaller all the time. Also noticed new engines being sold on Ebay in auction form starting at really low listings and selling cheap.
#365
Bump.............
#366
Nothing going on at axe rossi that I heard of they workin on some new engines from what I've been told don't know what thou they are very slow to respond sometimes if there's something u need let me know they normally answer me back within a day r two.
#367
Ok all you Axe Rossi guys i have a GREAT deal for you i have 2 Mamba X1 motors left from when i was Sponsored by Axe Rossi and now that i am Sponsored by Alpha i can no longer run them so hear is the deal 2 motors for $100.00+shipping one motors is all most new with only like 2 gallons on it the other motor has good pinch but will need a Rod soon.
Send me your email and i will send you a Pic.
#369
up
Just got time to stop by to say hi been working to hard I want to play
#370
Yea know whatcha mean time is kinda thin around here to but got a great race weekend comin up on tha 16th so I've been trin to get my truggy ready for that
#371
Hey any u drivers on here going to ams race in june just curious
#372
#373
yes sir think ill be running the x2 cobra its just so much smoother than my mambas but alot depends on what track they go with iam also trin some new clutch setups been runnin three shoe for a long time with no major problems but thinking that the 4 shoe setup will be a little smoother.
#374
Hey do any of you want an x2 with pipe I have one for sell its new I will be runnin the mambas so I don't need this one its for $375 wich is a steal they sell new around 450 if interested let me know my email is at bottom of page. Thanks
#375
Blackmagic do you have any axe lsk engines or parts for sell. I would like to have some mor of engines they also were a great piece but hard to find. The mamba p/s is suppose to fit but I don't know for sure
