AXE ROSSI Engine thread.....
Old 06-05-2011 | 03:05 PM
  #391
Default Chris Crews
Anybody ever hear from Chris Crews anymore? Wonder how he is getting along with those Alpha engines. Chris, if you get this let me know what you think of those will ya? Later
Djsmokin is offline
Old 06-05-2011 | 07:03 PM
  #392
thenova70ss's Avatar
R/C Tech Elite Member
Hey Dj i have been having some GREAT runs with my Alpha motors for the money hands down the best motors you can get for the price and the run times are out of this world.
My pit guy is Kyosho17 he is the Sponsored driver for Axe Rossi now and he even likes how my Alpha motors Tune and run i had a GREAT run with Axe Rossi for 3 years just stated looking at some of the Lower Priced motors out to day and sent Alpha my paper work and got picked up with a Better deal on motors then Axe Rossi was gone to give me.
Axe Rossi is a GREAT company i just think now days money is hard to come buy and to spend $350.00 on 1 motors is just Crazy and all of Axe Rossi top motors are way over priced for what you get. My Alpha motors cost 1/2 the price and i am getting 5 and 6 gallons out of them and you cant ask for more from a $240.00 motor & pipe combo.
Hope to be running for Alpha and Rc Pro for years to come i am all so a dealer for Rc Pro and Alpha now.
thenova70ss is offline
Old 06-06-2011 | 01:20 PM
  #393
Torian4000's Avatar
I have an AXE Mamba for sale. It's in excellent condition with 2.5 gallons through it. It was just rebuilt and pinched about a quart ago! http://www.rctech.net/forum/r-c-item...axe-mamba.html
Sorry for hijacking but I need to move it as I already have too many engines.
Torian4000 is offline
Old 06-08-2011 | 12:32 PM
  #394
Hi, does anybody know the right shimming for Mamba X1 running 25% fuel?
The button has a 3 stamped on it, and with one 0.2mm shim the squish is 0.55mm.
I think I read that there is a button with 2 stamped on it as well, which one is larger in volume?
Appreciate any help!
NitroVein is offline
Old 06-13-2011 | 03:30 PM
  #395
You want.18-.25 on your squish point are at least that's what I've read and been told! The mabma comes ready for 30% which is .20ths one shim so if u run 25% you could drop that some without hurting engine. Always remember to check the pistion doesn't hit bottom of head button hope this helps some.
kyosho17 is offline
Old 06-13-2011 | 04:51 PM
  #396
Thank you, that helps.
Problem is that there is only 0.1 and 0.2mm shims to buy from Axe Rossi, could try a 0.1mm shims, that would give a total squish clearance of 0.45mm. A colder plug could help to.
Not my engine, helping a friend so I want to get it as right as possible from the start.
Old 06-16-2011 | 02:42 PM
  #397
To be safe just run the 2mm shim u should be ok.
kyosho17 is offline
Old 06-16-2011 | 02:57 PM
  #398
He will order a 0.1mm shim, and if if he doesn't getting it to work I will go and help him.
Thank you for you´re help!
I must say that after seeing it run and looking inside it, it´s a fine engine!
Old 07-11-2011 | 04:35 AM
  #399
Default Axe Rossi rods
I replaced an OS .28 in my RC8T with a cobra X1. Loved the engine, awsome power across the board. Ran about 3-4 litres though it than gave it a race tune. Had a few tunning issues that were to do with the pipe I was using.Refitted the axe 2050 and the engine was running sweet. Went to a 2 day race,we were able to get a couple of hours practice in at the track the day before the race,engine was running strong with more than enough power and great run times temps were around 215/220F. Started the engine and run it for a couple of minutes on the strater box before driving around the parking area to get some temp into the motor. Engine stopped dead and had locked up. Pulled the exhaust and back plate off and found that the rod had broken at the crank. Pulled the motor down and found the crank was broken and the case cracked. As i was really happy with the engine prior to failure I am looking at buying another one but have some reservations due to the rod failures. I have read the threads here and it seams that the new axe rods have fixed the issue. Info also refers to a Go tech rod as a suitable fix. What is the part number for the Go rod. Has anyone had any failures due to the new rod breaking. I am not concerned with the bushes wearing out after 3 or so gallons as the rod is something that I replace after that much fuel.
Flip it is offline
Old 07-12-2011 | 05:00 PM
  #400
Man that's too bad sounds like some luck I would have I've had the x2's which have new rod and have had no issues the mamba however has had rod probs and it has new rod don't really know what's going on with rods at axe some good some bad I've gotten 7 gallons on same rod iam not sure on go rod number I know alpha rods work as well I've measured it so it should work for you
kyosho17 is offline
Old 07-28-2011 | 11:26 AM
  #401
Default Mamba and Corba X2 for sale
Hey Guys,
I am sort of a newbie on here and I am not able to get into the RC trade/sale area of the site. Anyone have any ideas for me. It says I don't have access to this area.
I am wanting to list my 2 Axe Rossi engines for sale. I have a Cobra X2 with one gallon Byrons 30 through it. On the start box it coughed and sounded bad. I pulled the back plate and it spun the lower conrod bushing. I replaced it with new Axe Rossi rod. Scratched the backplate some but runs good and seems race ready.
The Mamba has about 1/2 gallon of Byrons 30 and is running really great. I broke both of them in with the heat cycle method. I am asking $225 for the pair. Really a slow race season here and I am thinning down. We can use Paypal and I can ship for standard ship price, around 10 bucks shipping. Drop me an email at [email protected] if interested. Thanks Dj
Attached Thumbnails AXE ROSSI Engine thread.....-dsc00487.jpg   AXE ROSSI Engine thread.....-dsc00483.jpg
Djsmokin is offline
Old 08-12-2011 | 07:28 AM
  #402
stevepowling's Avatar
Hey everyone,
I have an Axe Sport .21 engine from a few years ago, it's brand new still in the box. I had it as a back up engine when I was racing 1/8th a few years ago. The current OS header for the OS RG I was running isn't the correct fit for the Axe, just wondering what header/pipe combo works for this engine?
stevepowling is offline
Old 08-23-2011 | 04:07 AM
  #403
Mate I have stuck with the axe rossi motors as they are a great motor except for the rods. I have used the GO PRO rods in both my axe .25 cobras with great results. My current race motor has got 20 litres on the rod and 25 litres total. There is no way you would be able to do this with the axe rod. The rods are $25 dollars and are a perfect fit. You can get them here. http://www.massivemods.com.au/produc...products_id=60
chalkie is offline
Old 08-23-2011 | 12:13 PM
  #404
Yea tha axe rod bushing is what ive trouble with both that went out only had about 2gallons on it but the engines are very precise. When i break in a axe engine i take a used but good rod to breakin then put new one back in after that. That seemed to help on the last one i done
kyosho17 is offline
Old 10-05-2011 | 03:41 AM
  #405
I have come back to the axe family after a short but unhappy time with another engine. Running another Cobra X1 Evo in my RC8T. Engine had the new rod so I ran it in with the axe rod then fitted an R7 rod that I had as a spare for the other engine. Even though the new rods have been an improvement I dont want to smoke another engine.Took it out for its first race over the week end and finished second overall for a 2 day event. Very happy with the engine/2050 combo. I have a 2096 Nova pipe that I am going to try next week end to see how it compairs, nothing ventured nothing gained, if it is no good I will run the 2050 again
Dave
Flip it is offline
