Like Tree349Likes
NOVAROSSI Engine thread....
Old 03-23-2016, 08:35 PM
  #8851
bash bros's Avatar
Originally Posted by motoclay
What's the trick/purpose of the 3 needle carbs? I just pulled the trigger on a mito7 for my truggy....noticed a 3rd needle...what's really for?
Pretty much just a decoration. Almost everyone just leaves it at the stock flush setting. But if you were to mess with it the midrange adjustment basically adjusts the position of the spray bar... but any gains are usually minimal and not worth the hassle.
bash bros is offline
Old 03-24-2016, 05:22 AM
  #8852
cczjordan's Avatar
I agreed with it. Is really decoration unless you over tune it will make the engine stupid
cczjordan is offline
Old 03-24-2016, 05:39 AM
  #8853
Maximo's Avatar
it allows you to move the fuel outlet to match the size of the venturi insert...use a small insert you move it inwards, use a large insert you move it outwards...Basically allowing you to maintain the same location in relation to the incoming air stream...... when you adjust it you also adjust the LSN with it...so if you turn the Mid out half a turn you would turn the LSN in 1/2 a turn.....
Maximo is offline
Old 03-24-2016, 07:08 AM
  #8854
Awesome! Thanks!! Simple enough....
motoclay is offline
Old 03-25-2016, 12:30 PM
  #8855
Default Elite 5
Ok guys,will a Werks 2058 be a descent pipe?I also have a ninja pipe 2042(suppose to be the same As a os 2060)got one of these elites on the way and trying to formult a plan.$s$ for a pipe.
smash8ight is offline
Old 03-25-2016, 01:08 PM
  #8856
What's the current Nova Direct coupon code? Thanks...
Herrsavage is offline
Old 03-25-2016, 02:05 PM
  #8857
HaulinBass's Avatar
Trader Rating: 16 (100%+)
well that gold edition nova 3 port absolute is selling is a pretty decent little motor for the price, the specs they list are wrong as its a square stroke motor but with 1.0s and std ae rc8 shoes its got decent bottom and enough top end for at least 100 foot straight and its just broken in.
running a werks 086 on it with an unknown smooth bend header(its my shortest smoothie) in an ancient cl-1buggy
https://youtu.be/9k9YKgPgthM
HaulinBass is offline
Old 03-25-2016, 05:48 PM
  #8858
elex300's Avatar
Trader Rating: 110 (100%+)
I'm looking for some options for a throttle return spring set up. I'm told a rubber band works or a spring. I'm also told this only pulls on one side of the carb so it causes uneven wear on the slide which effects tune. What are some options for this? Pics are helpful if possible.
elex300 is offline
Old 03-25-2016, 06:31 PM
  #8859
Jerm13's Avatar
Trader Rating: 36 (100%+)
Rubber bands, water balloons, silicon hair bands, springs... It really doesn't matter as they all do the same thing. As long as it closes the carb all the way to the idle stop, it doesn't matter.
I have never run without one honestly and I think it helps to "assist" the engine coming from WOT to idle...But as long as it closes smoothly, you should be fine.
Jerm13 is offline
Old 03-25-2016, 08:55 PM
  #8860
They can cause the carb to bind. I use a hair band and it is light enough to close the carb but not cause the carb to bind. Never ran one for 10 plus years.
Chris Reilly is offline
Old 03-25-2016, 11:35 PM
  #8861
Search "Carb-O's" at Amain..
Old 03-25-2016, 11:46 PM
  #8862
houston's Avatar
Trader Rating: 96 (100%+)
Goodys silicone hair bands
Unless you got a super cheezy carb you will be fine
houston is offline
Old 03-26-2016, 06:45 AM
  #8863
Integra's Avatar
Cant honestly say ive Ever had my throttle linkage ball pop off, Also a proper build linkage will technically never fall apart (vehicle to vehicle accidents aside)
So therefor i dont see the point of a Goody band anymore.
Integra is offline
Old 03-26-2016, 07:14 AM
  #8864
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
In case you wanted specific Springs, Novarossi Direct has these:
http://novarossidirect.com/THROTTLE-...NG_p_3383.html
1/8 IC Fan is offline
Old 03-26-2016, 10:56 AM
  #8865
houston's Avatar
Doesnt hurt to be safe
What ifs always get ya
Btw those metal return springs will wear your carb slide boot until there is a hole ,guaranteed
houston is offline
