NOVAROSSI Engine thread....
Insane pipeset for Roma!!
Hello my nitro fam ! I was out messing around today with my Roma and I slapped on the Max Power 2164 pipe set on omg insaneeee !! The throttle response from any rpm was incredible , and power was just insane , it was like it was electric. I have ran sooo many combos on the Roma like 41032-Medium- Long, 41001,41031, 9886,Picco 2046 , Ielasi 2186, etc you get the picture and the 2164 kills it all and I mean lights out bad ass!!! It mayyyy trail behind the highest top end performing pipe by maybe 500-1000k rpm but it gets there faster than anything else by a long shot and the trigger feel is just . If you have a Roma you must give it and shot. What’s odd is I ran it on the new Nova G5r in the same rig on road and it was very soft low and mid but it came on mid-high like it was hit with a nitrous shot for a short time causing wheelies at 35+ mph . It’s amazing how one pipe will act with one engine and totally different in another . I love this stuff .
I had 2 Ielasi Hummer Off Road Engines and have to change to 16% EU fuel instead of 25% fuel.
Normally you take out 0,1 cm head shim and tune your engine new.
I tried this but one engine need 0,1 more (head gap 0,75mm) and other one need one less (head gap 0,65mm). Now is my question why is this so different ?
Engine where i remove on was running good but when it was hot and died there was no chance to restart it (temp. 135°C).
I do not like this 16% EU fuel
Are you only counting the shim stack?
Can be several reasons:
- different components (piston or head button) are used giving that tolerance.
- there is a sleeve shim with one?
I always check the clearance with a piece of solder by squeezing it between piston and head button.
The head gap where for both engines with 25% fuel with measured 0,65mm gap. I removed or put a 0,1mm head shim when i changed the gap.
Some courios thing was with the engine with died and i can not restart pumped no fuel in the line. Only when close exhaust he gets fuel for a moment. With one shim more it was no problem.
That is what i not understand because normally you remove 0,1mm shim and engine is running with 16% EU fuel.
The only difference was the carburator. One has a lying needle and one needle is standing but i cannot imagine that this makes the difference.
When i compare it with othe engines (Ielasi OS engines turn higher that my nova and they always was great with 25%.
Fuel is the same manufacture and i used the same fuel which the OS guys use.
Maybe it is the exhaust which the Ielasi OS guys use because they have some special pipe which is very thin towards the manifold.
