NOVAROSSI Engine thread....
#8341
#8342
mito 4 is no longer in production hmmm
#8343
#8344
I was wanting to try one out in my buggy, but then I got thinking about maintenance and what not and the standard .21 Hudy tool wouldn't even work with the 14.5mm bearings would it? Not a deal breaker, but.....
That's weird, just looked 5 mins ago and the Mito 4 is still there.
#8345
#8346
How does it compare to the other 4 ports? Are the porting and timings different or is it the longer stroke that makes the biggest difference?
I Am not sure yet as I have not tested one..... but IMO the crank wont make too much of a difference as the sleeve is still the same sleeve as before and is not really aggressive enough to benefit from the crankshaft...but with that being said the Legend 4 is still a nicer engine then a BTT or Keep-Off 4........... Also it only has a 16.8 mm stroke whereas the Mitro 4 has the 17.6 mm stroke
#8347
#8348
It still stands to reason; very few of the Novarossi factory drivers are running the Mito.
#8349
As stated in the other topic there is no way to compare unless you have precise the same configured engines. The problem is that engines from a different model are for sure different timed and can have different materials. For sure a 1 degree difference in timing can give a different feeling in an engine and will give a wrong idea about the differences between a long stroke and an xtra long stroke.
#8350
Same porting = same output, different crankshaft/stroke = different powerband (delivery).
#8351
novarossi elite 5 vs novarossi p5 xlt
Hii I searching engine below 200$ and I prever for novarossi elite5 or novarossi p5 xlt.. Which one for the best tx
#8352
if you guys want to try something. try the new C5TGN. wow what a plug. Its a solid plug and super easy to tune.
#8353
#8354
Hey looking for some ideas . My engine flameout on me on the weekend low and behold air filter was letting in debri . What's the best way to clean internals ?
#8355
