NOVAROSSI Engine thread....
#9091
Try richening the low end. Good rule of thumb to use to know you are in the ball park for low speed needle is the pinch test. Pinch the fuel line and engine should die in about 4 seconds while idling. Longer than that too rich, shorter too lean. This is just to get in the ball park for low needle. Sounds like the typical low end lean and high end too rich to compensate for low end being too lean. Also set idle gap with a paper clip to start. These are tricks I have been shown and have worked for me. Set you high speed needle to factory which should be close to flush. Hope this solves some of your issues. Did you get a lean bog going down the straight or gurgling bog like the car doesn't want to get out of it's own way?
#9092
#9093
Lean bog at high rpms. Idle gap is set correctly. I've tried many times going back to factory needle settings and staring from scratch but it barely runs and is extremely lean when needles are flush. Could be an air leak or maybe my pipe is clogged. I'm going to seal the carb and change pipes and see what happens..
#9094
Yall have air leaks in the lines or tanks. Also maybe a fuel volume issue.
I've never seen a Nova carb have an air leak. Should be no need to seal it.
HSN usually about 1/2 turn in from flush (approx)
LSN always flush or slighly in when idle gap is correct.
If you have the LSN too rich & HSN too lean; you can get a midrange bog.
If you're on 30% ensure you're running a c6tgc plug or OD97t.
For the low cg heatsink/heads they can run up to 290*F without issue.
#9095
My bt4 plus bogs on the straight and runs super hot yet my HSN is way rich like 6 turns out from bottom. I replaced the exhaust gaskets and checked internals and nothing looks broken. No fuel leaks through front bearing. Still feels like I have lots of compression. Less than 2 gallons on it. Any suggestions?
#9096
LSN needle, I'm not sure flush (or slightly in) is accurate (at least from the Nova's I've seen). Depending on motor/buggy/truggy, I have seem most Nova's a couple turns (or more) in (with an idle gap of 1mm or less). It's super rich/bogging when the LSN is flush (stock setting: 5 -6 turns out).
But Maybe we are missing the boat...
Just my 2 cents.
#9097
Just don't get too hung up on where the needles are. I've got a p5 xlt where the hsn sits about a full turn in from flush and on the Elite 8 it's about a half turn out so it can vary quite a bit especially when you factor in different fuels, pipes, venturis, etc.
Getting the correct idle gap is probably the most important imho. If you don't have anything to measure you can remove your carb insert and back the idle screw out just where the carb closes. From there you can open it up 3/4 to 1 full turn and that should get you pretty close to .5 or .6mm.
Run it for a tank until it's fully warmed up, get the hsn in the ballpark aka not blubbering rich and not screaming lean either. Just a decent top end will do on the hsn to start with.
Once it's warmed up and your hsn is fairly close, throw it on your starter box and give it a good wot squeeze and keep leaning the lsn until the idle doesn't drop but stays up high and steady, clearing it with a good wot burst everytime you make an adjustment. Once you get the high and steady idle then you can drop your idle down. After that you can double check the hsn and make sure you've got it dialed in for good performance and plenty of smoke when you accelerate. You can usually lean it a couple hours if needed for your final race tune without having to mess with the lsn.
That's the quickest foolproof way I've found to tune a Novarossi.
If you watch that Bernard Durand video, that's basically what he's doing... also keep in mind when fine tuning the lsn you only need tiny adjustments. 1 hour is often enough to overshoot your mark.
#9098
LSN always winds up in but not "couple turns" until the engine is considerably older...
But. As you said, all that is greatly dependent upon insert size; clutch & vehicle.
Agree w/HSN needle -- flush or slightly in.
Just my 2 cents.
Just my 2 cents.
#9099
Bash, I actually watched that video again last night. I have a few questions that maybe you all can clear up.
I'm running the elite8. That's a short needle carb right? Lsn only comes into play when idling and first part of take off right?
If I go by the video, do I start the process with an idle gap of 0.5-0.6mm or should I start with a wider idle gap? If 0.5-0.6mm is about the right gap, to me, it seems like I need to start with a little wider idle gap to dial in the correct idle gap.
What is the cause of a temporary hanging high idle after wot? I've read it can be the idle gap is too big (what the video dials out) or the hsn is too lean. If both are true, how do you distinguish between the two (no boggin when wot). Any other causes of a hanging high idle after wot? People around me have said a lean lsn can cause this, but I haven't read anything credible that says this is true.
When leaning the lsn to get a high idle when setting the idle gap, how long should that high idle last? I think I read it should remain high for at least 20 secs. If less, keep leaning lsn.
Thanks, in advanced, for your help.
#9100
If I go by the video, do I start the process with an idle gap of 0.5-0.6mm or should I start with a wider idle gap? If 0.5-0.6mm is about the right gap, to me, it seems like I need to start with a little wider idle gap to dial in the correct idle gap.You can start with the gap larger & LSN richer so that as you lean the lsn the idle rpm will increase & stay steady until you lower/close the gap
most often I see this with the idle gap is slightly too large & lsn is slightly too rich. So post WOT its hot & momentarily too rich thus you get a hanging idle
it will maintain a high steady rpm until you close the slide via stop screw
#9101
#9102
Suspended
this is from novarossi
Screw clockwise the high speed needle "A" until it will stop. Do not force it otherwise
the tuning tip will be damaged. Once you reach the stop, unscrew counterclockwise
for 3 and a half turns.
WARNING: if you have to turn the fuel intake pay attention to:
- close the fuel tube
- change the aluminum rings (cod. 11016)
- tighten the high speed needle support with a torque of 2.3 Nm
Screw clockwise the low speed needle (LSN) "B" until it will stop while keeping the
carburetor barrel fully open, then unscrew the LSN for 5 turns (6.5 when using the
carburetor 24066 and 6 turns with the 24067).
WARNING: This guide will help to start your engine and could be used as a starting point for the
tuning, however keep in consideration that the tuning could change according to the carburetor that
you are using, to the operating temperature, to the track style and to the driving style.
The screw "D" is the medium speed needle. You can use it to have a finer tuning of
your engine. To restore the factory settings you can screw it clockwise until it will stop
and then unscrew counterclockwise for 1 and a half turns.
The idle screw "C" is used to set the minimum air passage between the barrel and the
carburetor body. This passage will control the rpm your engine will have when idling.
This screw must be screwed until the gap between the barrel fully closed (pressed as
shown by the arrow on the picture) and the carburetor body is approximately 0.6mm.
Before measuring this distance remove the Venturi.
#9103
Thanks. I see that on the exploded view manual now too. I'm going to try this again going by the video. I thought I had it running good this winter. Than pnb came along and pit man said it was running 290-300 in practice. I significantly richen the top end (at least 1/2 turn) and it still was running hot. I prob should have richen the bottom, but I thought it was a short needle carb so as long as it would idle and takeoff good, I thought lsn was good. I've never got it to run good since pnb.
