NOVAROSSI Engine thread....
#7621
As u mentioned it was break in on d bench sure will have more lube unburn inside d pipe especially with high lube fuel
#7622
Rossi S42BX question....
Just picked up a slightly used s42bx. I'm looking for recommendations on glow plugs....long/short? Brand? Hot/Med? Any help would be appreciated!
#7624
Keep Off 7
I ran this engine for one race season and it has like 2 1/2 gallons through it. It's starting to shut off after I bring the car in and it idles for like 1 to 3 secs. has a littl pinch you can feel. Plenty of Bottom end and top end is still present in the engine. I must admit I probably ran it to lean in the first season as I was new to Novarossi engines. Is it worth the rebuild or should I just buy a new engine? I tried raising the idle and richening lsn which worked for awhile while and the engine was idling kind of high but after a 20 min run (refueled of course) I stop the car and it shut off again. Brand new clutch was just installed as well. Any insight fellas
#7625
Was given a P5XLT with 6+ gallons. It seems to run ok and tunes good. Anything I can do to help keep the engine life going? Don't know if it helps but running Flashpoint 30%.
#7626
Try reduce d head shim if u running with 25% nitro, usually 2 to 3 gallon is expected if tuned for extreme power. Try fuel with castor/synthetic might help but if still have compression.
Anyway since is only 2 gallon +, i believe d crank pin still good so just get a repinch instead of rebuild, new conrod after repinch will do the trick. Hope it helps
#7628
Www.rayaracing.com
Curious ,which fuel?
#7630
#7631
if you went from VP to byron race, a retune will be needed for sure..
#7632
#7633
I think prolonged lean run resulted in premature ejaculation
#7634
