Like Tree352Likes
NOVAROSSI Engine thread....
Old 02-27-2015 | 08:17 AM
  #7501
sn47som1's Avatar
Hey guys, if you were going to run a Nova based P5 with higher timing what non-Nova pipe would you go with? 2058? Meilke 2041?
sn47som1 is offline
Old 03-02-2015 | 06:39 PM
  #7502
Werks 2058 is the perfect pipe IMO.
rage1945 is offline
Old 03-02-2015 | 11:29 PM
  #7503
Hey guys I got a novarossi beat 4 . Planning on replacing the bearings with ceramics can any of yall guys tell me what's a good ceramic bearing to install . I know there's boca , tko, avid,ect... Thanks
Artlosi is offline
Old 03-03-2015 | 02:40 AM
  #7504
Originally Posted by rage1945
Weeks 2058 is the perfect pipe IMO.
I agree
LosiFanBoy is offline
Old 03-03-2015 | 06:13 AM
  #7505
I need a bearing for a Nova keep off 7 port? Can anyone help?
Eastside777 is offline
Old 03-03-2015 | 03:04 PM
  #7506
22Racer's Avatar
I have been using Avids on engines I rebuild for over a year with great luck. They are also usually a bit cheaper.
Rex
22Racer is offline
Old 03-03-2015 | 10:19 PM
  #7507
Rex
Ok thanks just thinking if I should replace the front bearing with a ceramic or steel can't decide yet ..
Artlosi is offline
Old 03-04-2015 | 06:34 AM
  #7508
houston's Avatar
I HIGHLY recommend not using any other bearing than the 17011 steel (no real advantage with ceramic front) ,they are THE BEST front bearing on the market period
I have been using avid rear bearings for rebuilds with great success the last two years ,tko before that
houston is offline
Old 03-04-2015 | 08:27 AM
  #7509
Ok thanks will do that ..
Artlosi is offline
Old 03-04-2015 | 09:01 PM
  #7510
Agreed!! Double sealed too!! They are the best front bearing period!!
rage1945 is offline
Old 03-05-2015 | 04:20 AM
  #7511
zachattak's Avatar
So whats the average amount of fuel you guys put into your nova's before you can lean on them? Ive got about 2L on mine, all car park work. 1L of just slow, smooth accel with nothing over 1/4 rpm. The past 1L ive been stretching its legs a little bit at a time. Still rich enough i reckon i can reuse the fuel coming out of the exhaust! Haha.
TIA fellas!!
Zach
zachattak is offline
Old 03-05-2015 | 06:28 AM
  #7512
sn47som1's Avatar
I hear Novas dont really drop balls until 1.5-2 gallons, so before that I would stay on the rich side of the set up.
sn47som1 is offline
Old 03-05-2015 | 06:30 AM
  #7513
houston's Avatar
TIA fellas!!
Zach
You can race it at the point youre at just leave hsn a bit rich ,DO NOT LEAVE LSN RICH !! This will compromise front bearing seal
houston is offline
Old 03-05-2015 | 02:47 PM
  #7514
scrapsz's Avatar
I have both front & rear available for Keep Off 7 port. PM me or see this thread...Novarossi Items for Sale
scrapsz is offline
Old 03-05-2015 | 03:25 PM
  #7515
zachattak's Avatar
Awesome, thanks guys. My btt+4 and tuned bonito have about 1.5-2 gallon on each. I found after run in the bonito was a tad stronger in the pinch category. Is this normal?
Both are running fine, still well over 10min on a tank at race pace.
