Like Tree352Likes
NOVAROSSI Engine thread....
Old 12-08-2010 | 08:02 AM
  #736
what is a comparable plug to the recommended CT6 in a P5?
I am dabbling back into nitro after a running electrics and you (and I) can say I am a noob again. I did not have good luck with the recommended Nova plugs when I used to run over 2 years ago...the OD and OS plugs seemed to be much better for me back then.
I run in TX with 50%-80% humidity if that matters.
bohdi is offline
Old 12-08-2010 | 08:07 AM
  #737
houston's Avatar
odonnell 97t or 87t
the newer c6tgc plugs are pretty good , a touch on the cool side and a lil harder to tune but make great power .
let me know if you need anything
www.houstonsengineservice.com
houston is offline
Old 12-08-2010 | 08:10 AM
  #738
Originally Posted by houston
odonnell 97t or 87t
OK..school me
How do you know whether to use a Hot or medium plug? are there general nitro rules to live by?
bohdi is offline
Old 12-08-2010 | 08:32 AM
  #739
houston's Avatar
OK..school me
its usually a temperature thing but humidity plays a bit of a factor as well as how hot your fuel is ie. percentages of nitro .
higher temp is supppose to equal to cooler plug (not cold but medium) but high humidity can fill the combustion chamber with unburnable moisture drawn from the air which in my findings it has been found that keeping with a medium hot will help ignite the fuel better as well as keeping with the cooler plug and lowering deck heighth (shimming) .
cooler temps is supposed to equal hotter plug , usually stick with the medium hot and have no issues . 97t fits the bill in most all situations that is why it is highly recommended .
houston is offline
Old 12-08-2010 | 08:35 AM
  #740
Thank you so much!
BTW, thanks for posting your break-in procedure!
I will be using your heat cycling method on the mill next week!
bohdi is offline
Old 12-14-2010 | 08:07 AM
  #741
How do you know which venturi to use in a P5X?
the blue 6.5 is installed so is that the one best suited for the mill?
bohdi is offline
Old 12-14-2010 | 08:10 AM
  #742
Trevor Williams's Avatar
R/C Tech Elite Member
that's a personal preference for the most part, it depends on driving style, run time needed, performance needed, track size etc.....Monty will elaborate more Im sure.
Trevor Williams is offline
Old 12-14-2010 | 04:27 PM
  #743
houston's Avatar
truck 7 and a half buggy 6 and a half
houston is offline
Old 12-14-2010 | 05:54 PM
  #744
OK thanks and last question. I have the RC8B with this P5X and a dynamite 86HS pipe but the pipe is too short. I need a longer pipe. Would the 9901 be a better fit?
how about the Reedy pipes. They seem longer too but don't know if that would work that great as the 9901 or 86
reedy 2035 or 2039
bohdi is offline
Old 12-14-2010 | 06:55 PM
  #745
houston's Avatar
Wink
reedy 2035 or 2039
get a new pipe hanger
houston is offline
Old 12-14-2010 | 07:30 PM
  #746
Sure, I can use a coat hanger to span the gap.....It is WAY short...I know it will work but it just seems so busted and horribly pieced together
bohdi is offline
Old 12-14-2010 | 09:02 PM
  #747
jnc011994's Avatar
btw , do you know eduardo coseteng from over there ?
one of my very good customers and a super good guy
Hi Monty,
If you mean "Jody Coseteng" then yes, i know him... consistently running in A-Main in many races here in the Philippines. Customer? did he ordered something? And yes superb guy, very helpful to us.. noobies..
jnc011994 is offline
Old 12-15-2010 | 12:03 PM
  #748
houston's Avatar
Originally Posted by jnc011994
Hi Monty,
yes thats him and he is more than a customer , a good guy and i stay in close contact with him as much as i can anyway and he has been the customer who has purchased more than 10 others combined
he must have about 20 engines from me if not more
he loves those toro nero team engines
houston is offline
Old 12-15-2010 | 12:04 PM
  #749
houston's Avatar
reedy 2035 or 2039
truggy , the engine rocks with either 2084ss or 9853ss and 41021 header
houston is offline
Old 12-15-2010 | 12:41 PM
  #750
I am running buggy and prefer a 7inch pipe (I know, that is what she said)
the 2039 I hear is more of a top end pipe similar to 086 but wondering on the 2035.
bohdi is offline
