Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-28-2013 | 07:19 PM
  #6076
Imbue's Avatar
Originally Posted by kgombe
The JP or the RS version
The super-strong RS version.
Imbue is offline
Old 09-29-2013 | 07:27 PM
  #6077
mrbusta's Avatar
Hey guys I have a nova plus 4 factory tuned with a standard head
Button. Now a good friend has got me a turbo head button for
This motor we have no dramas to change them over wich I
Would like to do. But we are confused regards shimms from button
To button do we use the shimms from the old to new button
Or????? Any help would be greatly appreciated tanks guys
mrbusta is offline
Old 09-29-2013 | 08:11 PM
  #6078
Maximo's Avatar
Use .8 mm total shim...2 silver 0.3 mm and one brass 0.2 mm
Maximo is offline
Old 09-30-2013 | 01:41 AM
  #6079
mrbusta's Avatar
ok thanks you very much appreciate your help
mrbusta is offline
Old 09-30-2013 | 05:03 AM
  #6080
Default Novarossi S21P5XLT .21 Not turning over
Got this new motor a while ago started once ran ok for about 30 seconds then stopped, time became an issue and i havent touched it since about 6 months and after trying differant techniques to loosen the fly wheel ( heating the head taking out glowplug and then heating the engine) it just doesnt want to start or turn over? really need help!
gjshort is offline
Old 09-30-2013 | 09:27 PM
  #6081
Guillermito's Avatar
Hi, I have a Keep Off 7S in Mugen truggy, and let me know that I recommend venturi: 6.5, 7 or 7.5mm?
Thank you. Best Regards.
Guillermito is offline
Old 10-01-2013 | 03:26 AM
  #6082
beidle99's Avatar
6.5 or 7. I have always run the 7mm in buggy.
beidle99 is offline
Old 10-01-2013 | 06:54 AM
  #6083
psr's Avatar
psr
Hey guys I'm just asking this on here as I think the 2096 seems very similar to a os 2060
Has any one used a ninja or os header on a 2060 on a btta a or fusion
psr is offline
Old 10-06-2013 | 11:10 AM
  #6084
Hi, I am running in a Keep Off 4S. How many tanks do y'all run through it before race tuning it?
Thanks. Best Regards.
Old 10-06-2013 | 02:03 PM
  #6085
portyansky's Avatar
Take the back plate off see if the rod is broken
portyansky is offline
Old 10-06-2013 | 05:41 PM
  #6086
I have a NovaRossi MT12... Old school
Is the backplate the same as a Picco? Is a Picco #5051 the same as a NovaRossi 13600?
Is one better than the other? The Picco seems to have a rubber o-ring that I'm guessing may seal better.
Thanks in advance...
JSchubz is offline
Old 10-08-2013 | 08:39 AM
  #6087
savannahmick's Avatar
Default Delete
Delete
savannahmick is offline
Old 10-15-2013 | 02:26 AM
  #6088
Hi all. Can someone help me to choose Nova Rossi best engine.
I use it on buggy 1/8
46 spur 13t clutchbell
43 crown gear 13t pinion
30% nitro fuel
I'm looking for Top speed
dafoets is offline
Old 10-15-2013 | 02:56 AM
  #6089
houston's Avatar
30% nitro fuel
Sounds like you would like the bonito/keep off 7 , its definitely got some rpm
houston is offline
Old 10-16-2013 | 04:27 PM
  #6090
scrapsz's Avatar
7mm in the truggy
scrapsz is offline
