Like Tree352Likes
NOVAROSSI Engine thread....
Old 08-19-2013 | 11:03 AM
  #5941
sschultz's Avatar
Originally Posted by mutt_c
Does someone have a diagram showing the idle / low / high needle locations on a Novarossi offroad .21 engine. keep in mind this engine is about 8 years old but practically new due to not being run for several years. I've been looking online for diagrams and unable to find anything.
Thanks.
http://www.racing-cars.com/images/te...i/s21p5xlt.pdf
11015 is the idle
11034 is the high speed
11006L is the low speed
sschultz is offline
Old 08-19-2013 | 12:54 PM
  #5942
copey70's Avatar
Originally Posted by Maximo
Well a few things that I think will help in order of importance..
Drop the stock Losi clutch in favor of a M2C with hard shoes.......
Drop the 9853/41021 in favor of a 9886/41001
drop the Byrons race in favor of Werks or Bones brew fuel ( Byrons race gives up noticeable HP to these other 2, especially bottom end crispness )
Thank you Neal, I will give this a try and see how it goes
copey70 is offline
Old 08-19-2013 | 04:50 PM
  #5943
revo61's Avatar
Has anyone used Reedy glow plugs in there Nova? Any problems?
revo61 is offline
Old 08-19-2013 | 06:12 PM
  #5944
houston's Avatar
or just try to use higher stall clutch and make sure you have the right clutch bell (losi branded) not a protek or similar as they are different i.d. and will cause the shoes to engage much earlier than they should
try all aluminum with either all gold or 2 green 2 gold or 3 gold 1 green
light blue shoes
houston is offline
  #5945
houston's Avatar
any glow plug works Theo , they are short taper like os i am 99% sure
houston is offline
Old 08-23-2013 | 11:45 PM
  #5946
D-StyleNZL's Avatar
.21 Keepoff 21-4 or XL vs. .25 Roma
Looking to get a new Truggy motor for racing. Race mainly on tight tracks which require more Mid range than all out Redline top end.
What would be the best motor for Fuel economy and Mid range punch?
What pipe would work for reckomended motor?
D-StyleNZL is offline
Old 08-24-2013 | 04:46 PM
  #5947
Was wondering has anyone ran a werks 2013 pipe on there bonito in truggy and how did you like it? I have one but havent tried it and was curious.
rcmoe is offline
Old 08-24-2013 | 06:56 PM
  #5948
croracer's Avatar
I thought your bonito was broke, the pipe won't work on a broke motor
J/K rcmoe
croracer is offline
Old 08-24-2013 | 07:18 PM
  #5949
Thinking of switching over to nova. Currently I have a os speed .21 & .19. I will be running buggy and truggy. What are some recommendations?
Preciate it..
gixxer420 is offline
Old 08-24-2013 | 08:30 PM
  #5950
wingracer's Avatar
I've never run one on a Bonito or a truggy but I have yet to find a motor that a 2013 isn't at least really good on. I've run them or worked on cars with them on every onroad motor out there plus offroad Werks, RB's, P5's, Piccos, BTTs, OS, and even a .28. IMO, it's the most versatile pipe on the planet. Only 2058s and the old Novas like 9886 and 9853 come close. Try it. I guarantee it will work well. Whether it's the best or not is up to you.
wingracer is offline
Old 08-24-2013 | 09:40 PM
  #5951
sschultz's Avatar
Not to mention, that sweet note they sing! My favorite sounding pipe, hands down....
sschultz is offline
Old 08-24-2013 | 10:21 PM
  #5952
J/K rcmoe
My Bonito is perfectly fine. Its been sitting up waiting to break you off with ..Btw, has anyone tried a 2013 on plus 4 tuned? I just picked me up a nice good used one and I'm trying not to spend on a pipe right now.The only other pipes I have is an 086 which I use on my Bonito which I like to keep intact in my trugg and I have an efra2071 (re11). I'm going to be running the plus 4 in my buggy. Thanks for all the feed back
rcmoe is offline
Old 08-25-2013 | 04:07 AM
  #5953
psr's Avatar
psr
hey guys I need a hand yall
I was running a btta in my mbx6rt and was killing 1.1 mugen springs every run
I was going through 3 a run arfter I killed 9 springs I actually swaped motors out for a speed
ive always run 1.1 in my buggy this is the first time I ran a mugen truggy ?
the springs wernt burnt or looked hot clutch bell however was slightly blue
did they over heat you think ?
psr is offline
Old 08-25-2013 | 05:06 AM
  #5954
sschultz's Avatar
Most steel gets a bluish tint around 780°f. So I would say you had a lot of slippage going on.
sschultz is offline
Old 08-25-2013 | 07:01 AM
  #5955
nickdawg18's Avatar
Hey guys. I have a nova plus 4 btt and a nova p5xlt. Both engines scream down the straight and have great acceleration but when I pull in for fuel, they are both running at about 290-300 degrees. They both look like steam locomotives with the good smoke coming out the pipe. Both engines are sealed with lucky 7. Is it time to replace the front bearings? And would a bad rear bearing make the temps rise?
nickdawg18 is offline
