Like Tree352Likes
NOVAROSSI Engine thread....
Old 12-10-2012 | 08:18 AM
  #4651
houston's Avatar
Originally Posted by yollie
is tuning 24065 carb is the same as the previous carb. i read the bible and this carb really hard to tune it is there anyone have same problem with me?? or it just me. i can't
get a good tune
It is not so easy to tune , I noticed some of them have to be REALLY lean on lsn and there is about a 1-2hr window
houston is offline
Old 12-10-2012 | 10:24 AM
  #4652
Lille-bror's Avatar
Lille-bror is offline
Old 12-11-2012 | 03:33 AM
  #4653
this carb really drive me crazy. its my new quest b4 new season. quite challange there
yollie is offline
Old 12-12-2012 | 06:05 PM
  #4654
Guillermito's Avatar
Originally Posted by OleC
What header is he using?
Whats the difference between the 9901 and the 2096?
The header is the 41021, because this is MBX7 wider chassis. The 2096 pipe works best with 4BTT, because it gives better power delivery and reduced fuel consumption.
Guillermito is offline
Old 12-12-2012 | 06:11 PM
  #4655
kgombe's Avatar
monty is correct.. you have to go really lean on the low speed..
kgombe is offline
Old 12-13-2012 | 09:40 AM
  #4656
houston's Avatar
Originally Posted by merdith6
That pipe looks like a thin version not the SS version so they put a reinforcement on it. Similar to the 9901 thats thin.
Yep
The thin pipes work very good but not worth the loss in sturdiness imo
I believe the reason for the thin pipe is the weight savings for Roberts buggy
houston is offline
Old 12-13-2012 | 09:49 AM
  #4657
merdith6's Avatar
Default So true
Yep
I usually get flat spots on the bottom of thin pipes. I like the ss ones the best too.
merdith6 is offline
Old 12-13-2012 | 12:04 PM
  #4658
maddog74's Avatar
I wish they would make the ss pipes with the reinforcement stinger. That is the only place I think the Nova ss pipes are weak.
maddog74 is offline
Old 12-13-2012 | 12:09 PM
  #4659
merdith6's Avatar
Default True
A fat weld around the stinger and or a reinforcement would make the SS pipes last forever.
merdith6 is offline
Old 12-14-2012 | 04:28 AM
  #4660
Need your guys help.
I bought a new assembled DNX408 buggy off flea bay and it has a New never ran Toro Nero in it. I have been reading about the power of this engine and have concerns of keeping it , as its a powerhouse. Not to sound like a wuss here but I would rather have a more conservative engine , It has a 2084 SS nova pipe on it. If I do keep it what pipe would tame this beast... or should I just sell it to a truggy owner and pick up or trade for a Plus 4???
dan-o is offline
Old 12-14-2012 | 04:42 AM
  #4661
Maximo's Avatar
the 2084 will tame that engine right down, you will not have any issues ..........Out of all the pipes I tried on those engines the 2084 reduced the power about the most.......
Maximo is offline
Old 12-14-2012 | 02:46 PM
  #4662
micke_b's Avatar
Which nova engine / pipe combo would give me the longest runtime? Which combo can I make 10 minutes pitstops with comfortably?
micke_b is offline
Old 12-14-2012 | 02:58 PM
  #4663
SEF's Avatar
SEF
Unfortunately it is more like engine, manifold, pipe, clutch set up, drivetrain efficiency, track size, track layout, track surface, and most improtantly drivestyle combo that will yield long runtimes.
The 9901 is supposed to be the long runtime with softer bottom type pipe. I personally like the 2096 and the 9853 pipes. I have all three and it is not always the 9901 that yeilds the longest runtime for every track for me.
Experiment. Because some pipes, you may loose a little runtime, but you may be generally faster around the track.
SEF is offline
Old 12-15-2012 | 04:54 AM
  #4664
Maximo's Avatar
runtime is mainly to do with the driver and his/her skill tuning the engine...I can make about anything make 10 minutes with careful tuning, even modified 28's...........My advice is match the engine to your driving style first, then start worrying about runtime.....
Maximo is offline
Old 12-15-2012 | 07:18 AM
  #4665
merdith6's Avatar
Default runtime
I find that out of the Nova engines I have the runtime is about the same.
The altitude seems to be the biggest factor in mileage. I live near sea level and it requires a richer setting.
merdith6 is offline
