Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-23-2012 | 07:03 AM
  #4036
what happen with my engine it only goes 5-6 minutes OMG i use 6.5 venturi restrictor and new carb. and my LSN 2 turn out is there any thing wrong....
yollie is offline
Old 09-23-2012 | 07:46 AM
  #4037
aznitronut's Avatar
Pipe/header? How much fuel has been thru this engine? Clutch?
aznitronut is offline
Old 09-23-2012 | 08:08 AM
  #4038
beidle99's Avatar
Check your fuel system. You could have a leak at the tank or in a fuel line causing it to loose massive amounts of fuel.
beidle99 is offline
Old 09-23-2012 | 08:13 AM
  #4039
BradS's Avatar
Just finished breaking in a P5xlt, a month after breaking in a +4. The p5 seemed much easier, that thing screamed right away. Seems like it took all the way to 2 gallons for the +4 to come around
BradS is offline
Old 09-23-2012 | 03:59 PM
  #4040
I have a p5xlt that I just got with a 811 buggy and it only has about 3/4 gallon on it but I need to retune it. Does someone have a good base line for the settings. Thanks.
JoeC is offline
Old 09-23-2012 | 07:10 PM
  #4041
BradS's Avatar
When I get tune out of whack, I like to go to the base carb settings and then adjust from there.
http://www.novarossi.it/files/manual...21-REVERSE.pdf
BradS is offline
Old 09-23-2012 | 07:15 PM
  #4042
Muggydude's Avatar
The plus 4 has the hard team piston, which takes longer to break in but also lasts longer. P5 does not. Still great quality though.
Muggydude is offline
Old 09-23-2012 | 07:42 PM
  #4043
My engine is VERY loud, though I think it's the pipe. Is there any other factors that can cause my engine to be very loud? It's a 21-5 or FMS? I'm not sure, but it's one or another. It's being broken in as well but my other N21R that is getting broken in at the same time is quiet with a 9901/41021 combo.
fung_kyle is offline
Old 09-23-2012 | 07:44 PM
  #4044
Suspended
My P5 has that piston, team piston
Runs awesome
rcuser567345 is offline
Old 09-23-2012 | 07:56 PM
  #4045
I have the p5xlt in my 811T truggy and wanted to know if there was a better choice than what I have. I am coming back to nitro after taking a year off so having to relearn a lot of the nitro stuff. For tuning, power, and durability should I be running a different Nova or is the p5 sufficient?
JoeC is offline
Old 09-23-2012 | 09:52 PM
  #4046
blade954's Avatar
Still run a P5 today nothing wrong with ours just pipe changes for different tracks. Although the Roma is becoming popular. I think the P5 is more than enough if your getting back into it run it and have look at what's out there.
blade954 is offline
Old 09-23-2012 | 11:26 PM
  #4047
bigjayjay1's Avatar
The P5 is a great engine for the price. Clutch, pipe, header, and Carb restrictors are your best mates. If you need more power use a 8 or 9 restrictor. Pipes are important geez I must have over 15 pipes pending on engine and mood. You can always send or buy an engine for a Mod which will help. You could buy a stronger engine as an alternate that way you have something in your box for those high bit days. I'm not a pro in any means if your not able to drive consistent then no engine will be good enough.
I saw a few clips of your track and it looks very fun. You have the track for a high hitting engine if your interested give Clockworks a ring or a person you feel comfortable with and ask questions about Modding and engine.
bigjayjay1 is offline
Old 09-24-2012 | 10:16 AM
  #4048
For the 21-5 what would be a good combo I have a 41005 manifold only... I can buy used off here, so what's a good combo or is the 9901/41021 the best combo as of now?
Old 09-24-2012 | 12:17 PM
  #4049
Thats happened, because you are use incorrect insert.
The internal channel inside of the new carb is 6.0....
And when you are install 6.5 isert, you make a "step" for flow....
Sorry for my english
Sergey D is offline
Old 09-24-2012 | 12:22 PM
  #4050
Suspended
Neal says 41005 makes the engine feel lazy, 41001 would be the best, a lot better than the 41021.
