The New Werks B5 .21 Racing Engine
#1292
BTW, don't forget to recharge your receiver battery while breaking the engine in. I almost had a runaway this morning on an LiFePO4 battery. I normally recharge after four tanks, but seven tanks (plus 1.5 before the case broke two weeks ago) is almost 75 minutes of runtime and equals intermittent connection. Luckily I wasn't at full throttle when it decided to go.
The 1400mah pack took a 1100mah balance charge.
#1293
#1296
I agree also on the when an enige wears out to most of the time replace it. Its so awesome that the B5 is such an incredible engine and cost only $199. I never liked the fact of spending $300-$400 on an engine and if Iwanted to rebuild it it would cost over $250 for a p/s,rod and bearings. Its great that with the B5 you get all the power and quality of a $350 engine for So much less! Yet, if you do want to rebuild it WERKS parts are pretty reasonable.
#1297
While I didnt have an A main win, I did have another reliable weekend of running B5 engines and Werks fuel. Its feels good to not have to worry about that part of your race program...
For $200 I would rather replace than rebuild.
#1298
Ron's fuel is very good, as well, I have friends who use it with great results.
Byron's is also some of the most expensive fuel you'll ever find at a LHS. It's good, but Ron's WERKS fuel is cheaper and better, IMHO
Markhat250... your B7 screams! so does your m-spec. Thanks for the pit help today, and I'm glad you're liking your WERKS gear and fuel
#1300
you really wanna be running 30%... and i personally think that 11% oil is waaaaaaaaaaaaaay too much. Ron's thread, so I won't preach too much but I like torco... I've been running it since beta testing last summer. The current batch out there is something like 8%... we just tested a new batch that's unavailable as yet that is even less, and gives a bunch more run time.
#1302
Same Pipe... I believe they come from the same factory in Italy... I run the Orion 2013 and it has been flawless. VVery durable also. It worked in a crunch when I could not find the Werks 2013.
#1303
Well I have put some more tanks on my new B5. (About 15 total) I decreased the air gap to .5 and I'll tell you guys I love this engine. Its idling great and has excellent low end. Quite a bit more than the B7 IMO. The werks 30% is working good too. I timed two tanks the yesterday and I got 11 plus min with the 2013 pipe. So I would agree with the other posts, At 199.99 a pop..keep 'em coming.
#1305
I havn't really delved into run times, but hope Ron could pipe up on what maybe Kortz has experienced. If it is real close, I think I favor the B7pro for my style (I've tried it in buggy and truggy now). The B5 is nice and I love it, I just love to pin the crap out of it and rpm it to the moon, regardless if I'm winning or not
. I do run a slightly heavier clutch spring to help out the 7 port bottom.
Ron, I'm now using your new 2013 pipes and Werks 30% fuel and liking the results. I'm sticking with my Werks stuff untill someone pays me to do otherwise
63Likes
