EB Mods JS Engine
Old 09-07-2010 | 08:58 AM
  #1231
bboard's Avatar
Originally Posted by jbright33
bboard carb needles out of box are half turn in from flushtop and bottom and idle is 1 1/4 turns from closed i think its been awhile. as far as temp iv never temped my motor so have no clue about that but i will tell you the js cools down very very quick so to be accurate you gotta pretty much do a pit stop temp.as for my full mod settings im at 1 1/4 turn in on top and 1 3/4 in on bottom using p5 plug and ebmods 30% and dyno86 pipe
I was only temping the motor to make sure it isn't running way too hotm and I'm temping while the motor is still running. I was at 3/4 on top and 1 turn on bottom, and it was getting there. Running p3, Byrons30, and Dynamite 086. I gotta say that even with an off-tune this motor hauls especially on the bottom end.
bboard is offline
Old 09-07-2010 | 05:07 PM
  #1232
Mikey-B's Avatar
Thumbs up
I ran the JS race prep motor at Family Hobbies this weekend and WOW.....three 6 min quals, 15 min B main bump and 30 min A main, no flame outs .......all with great power from bottom to top....... and 10 min pit stops too......Ed, you the MAN!!
Mikey-B is offline
Old 09-07-2010 | 05:30 PM
  #1233
jbright33's Avatar
bboard iv seen guys temp like a pit stop then let the engine idle for 30 sec and and temped again and it has already cooled 20 degrees very fast cooling at idle and shut off. thats what i was trying to tell ya. but just go easy with the needles you may find out by the time you find the sweat spot the low spead needle may be in alot further then you would think.
jbright33 is offline
Old 09-09-2010 | 12:27 PM
  #1234
EBMods's Avatar
Awesome to hear Mike!!!
EBMods is offline
Old 09-09-2010 | 12:31 PM
  #1235
EBMods's Avatar
What are the starting points on the needles?
All the carb needles were flush out of the box, after a full turn all around the motor is still rich, and the motor is only temping at 200* after a tank. I dont want to go to far in, is this normal?
Jesse is correct for the box settings, let use know if you need more help.
EBMods is offline
Old 09-09-2010 | 12:33 PM
  #1236
EBMods's Avatar
Originally Posted by jackhammer
Rome ,ny. CRC raceway
What's the date for this Race? Maybe I'll see about coming up to race, CRC is only 3hrs away.
EBMods is offline
Old 09-09-2010 | 12:44 PM
  #1237
EBMods's Avatar
A Main Hobbies has the current Full Line of JS Racing / EBMods products in-stock. Please check out all the new items
http://www.amainhobbies.com/index.ph...cturers_id/673
.23's and more .21's are shipping from the factory and should be here next week.
EBMods is offline
Old 09-09-2010 | 05:25 PM
  #1238
jackhammer's Avatar
This sunday the 11th thanks will be looking forward to the .23 making it to the states just got this one now got to buy a .23
jackhammer is offline
Old 09-09-2010 | 05:51 PM
  #1239
awdcameolsx's Avatar
I had one of these motors this season and loved it but am curious is there plans for a counterweighted crank version? I only asked because this motor had just a little more punch on the bottom end for my taste. I was also curious if anyone know but would a steel flywheel have the same affect as a "balanced" crank?
awdcameolsx is offline
Old 09-09-2010 | 06:05 PM
  #1240
jpalessi's Avatar
YES! the .23 Full Mod version will have a tungsten weighted, balanced crank.
this crank will be available as a part for the .23 FM and will work VERY GOOD in any of the current JS/EBMods engines.
jpalessi is offline
Old 09-09-2010 | 06:10 PM
  #1241
jpalessi's Avatar
Default EBMods JS Racing .23 "HELLFIRE"
jpalessi is offline
Old 09-09-2010 | 06:16 PM
  #1242
JUD's Avatar
JUD
Nice!!!
JUD is offline
Old 09-09-2010 | 06:19 PM
  #1243
hookem34's Avatar
R/C Tech Elite Member
Default Square bore?
What is a Square Bore design?
hookem34 is offline
Old 09-09-2010 | 06:22 PM
  #1244
338lapua09's Avatar
Gotz too be having one of these bad boys I think im becoming a JS engine whore and I like it
338lapua09 is offline
Old 09-09-2010 | 06:23 PM
  #1245
jpalessi's Avatar
stroke and bore are the same. hence square stroke design.
^ with a long rod!
jpalessi is offline
