EB Mods JS Engine
Old 05-05-2010 | 07:40 PM
  #706
jpalessi's Avatar
Originally Posted by tc5 man
so is it ok for now to just take a shim off the head if i get this engine so i can run 20% for now? or just run the 20% i leave it alone? i have a 86 pipe im gone to run this engine in a truggy.
no do not run 20%, and do not adjust the shims. run 25% that you said you have, and swap the 20 when you see us.
jpalessi is offline
Old 05-06-2010 | 01:47 PM
  #707
pballer2777's Avatar
so i just got my race prep today with a dyn 086 pipe. my question is what carb insert should i use. its goin a 8t 2.0 and i race mostly a med size track.
pballer2777 is offline
Old 05-06-2010 | 02:18 PM
  #708
nitro crazy's Avatar
just wondering what the big difference is between the full mod and the race prep, seems like more people favor the race prep motor for some reason, just wondering just bought the full mod version can't wait to get her going. thanks...
nitro crazy is offline
Old 05-06-2010 | 02:23 PM
  #709
hambone's Avatar
They work best with the 7mm.
hambone is offline
Old 05-06-2010 | 02:27 PM
  #710
hambone's Avatar
Full mod spools up a little faster and revs a little higher than the race prep. Rotating assembly being lighter and ceramic bearing makes the difference.
hambone is offline
Old 05-06-2010 | 03:19 PM
  #711
jpalessi's Avatar
I run the 8mm stack in mine, but some like the 7mm. Anything smaller then a 7 starts to take away from the top.
As Rob said the Full Mod internals are lightened and balanced, and come with a TKO ceramic rear bearing. The lightened internal and ceramic rear bearing make for a faster rev, more peak hp & rpm.
jpalessi is offline
Old 05-06-2010 | 03:36 PM
  #712
tony montana's Avatar
joe, do you think my stock js would work in the truggy ok? Or do you think I should run it in my buggy and leave the ninja in my truggy
tony montana is offline
Old 05-06-2010 | 05:01 PM
  #713
jpalessi's Avatar
I would leave the JX in the buggy and run the JS in the truck. The JS will throw the truck around better imo.
jpalessi is offline
Old 05-06-2010 | 05:22 PM
  #714
JUD's Avatar
JUD
yup i do race at hobby hut, every other weekend or so, i know i could use 25% but i have a lot of 20%, left so i dont want that to go to waste.
i know i can take off a shim, so i can run 20% for now although i dont know how it would run though if, i break it in with 20% and than go to 25%.
Hey TC5 just do what Joe says. He won't steer you wrong. you will love your engine with 25-30%. Best of all you will be pleased with the performance!!
JUD is offline
Old 05-06-2010 | 05:52 PM
  #715
thanks joe, So run my stock js in the truck then
Old 05-06-2010 | 06:02 PM
  #716
jpalessi's Avatar
yep, what pipes and plugs do you have?
jpalessi is offline
Old 05-06-2010 | 06:20 PM
  #717
the ninja 2042, which is basically a 2060. And the losi pipe that is like the 2050, and p3 glow plugs
Old 05-06-2010 | 06:26 PM
  #718
jpalessi's Avatar
ok out of the 2 pipes mentioned they both work ok, but a 086, 9901, or 2041 would be my choice. these are the best I've seen run. The OS P3 plugs are MUCH too hot, and are not recommend. I would pick up some OS P4's or P5's. I like the P5 myself, with a 2041 pipe, and a 8mm stack.
jpalessi is offline
Old 05-06-2010 | 06:38 PM
  #719
Who8mySandwich's Avatar
I'm currently getting 12 mins. with the JS full mod with P6, TT 2039. Temp. at 205
Who8mySandwich is offline
Old 05-06-2010 | 07:53 PM
  #720
jbright33's Avatar
so i picked up a older top 9886 from my one buddy im gonna give it a try on my truggy c what happens.
jbright33 is offline
