EB Mods JS Engine
Old 03-13-2011 | 12:13 PM
  #1711
Originally Posted by Mikey-B
is that 12min on a buggy or truggy?
Buggy
Shocker is offline
Old 03-13-2011 | 06:52 PM
  #1712
Mikey-B's Avatar
Originally Posted by Shocker
Buggy
wow....nice
Mikey-B is offline
Old 03-14-2011 | 10:06 AM
  #1713
338lapua09's Avatar
Sounds like EBMODS is moving to a new location 3/11 to 3/18 .
Good luck Ed with your new build/move I hate moving my self couldnt even think of moving a company.
338lapua09 is offline
Old 03-14-2011 | 12:52 PM
  #1714
STUBYSLAP31's Avatar
R/C Tech Elite Member
Default Few questions?
Ok so I have been planning on running a vspec again this year. This year is a little different as I'm trying to keep it as afordable as possible.
I am looking at either the stock .21 or the race prep. What is the difference. How does the js compare to the os?
Also how is the carb on this engine, there are lots of great engines with bad carbs
I'm looking at ordering either a dyn 053 or 086 pipe. What would you recommend
I live in Colorado springs co and all of our tracks are between4700 and 5700 ft in elevation. I run 40% Byrons prodriver. What plugs do you suggest. Do the odonnel 77t or 99t plugs work as well,'or are the os plugs the way to go. Also any head shimming adjustment needed with my set up.
STUBYSLAP31 is offline
Old 03-14-2011 | 02:34 PM
  #1715
The stock .21 comes just like every other engine on the market. The Race Prepped engine is hand built, fully inspected, bearings aligned, etc. And most importantly it's broken in for you, so all you need to do is put it in your car and go race. No need for the headache of breaking it in on your own.
If you're going to buy a dynamite pipe for it, order the 2081 (DYNP5008) before the 053 or 086. The 053 seems to create a weird hesitation on power and the 086 makes the power band hit too hard for buggy.
As for plugs you can run the dynamite #4 (xtra hot) plugs to help with the elevation and save some money over the OS plugs. You may need to add an extra head shim as well but with 40% nitro and an extra hot plug it may run fine right out of the box.
Shocker is offline
Old 03-14-2011 | 03:08 PM
  #1716
i went ahead and ordered the stock version, with some p4 plugs. i will look into the 081 pipe, i liked the 053 and 086 becuase of the price and because its hard annodized..
Old 03-14-2011 | 05:43 PM
  #1717
moto-x-107's Avatar
what pipe is good for this motor
moto-x-107 is offline
Old 03-14-2011 | 06:07 PM
  #1718
hlpressley's Avatar
So the 2081 is the way to go for a buggy? Looking for as smooth of a powerband as I can get.
hlpressley is offline
Old 03-14-2011 | 08:13 PM
  #1719
moto-x-107's Avatar
yeah its for my buggy 2081 from who
Old 03-15-2011 | 09:38 AM
  #1720
Well with shockers suggestion I ordered up an engine with the 2081 dyn pipe.
Do you guys have a standard needle setting for when the engine is fully broken in.
Old 03-15-2011 | 09:51 AM
  #1721
motomatt's Avatar
If you're running 40% at 5,000ft. Their needle settings won't be of much use to you.
motomatt is offline
Old 03-15-2011 | 11:25 AM
  #1722
will g's Avatar
If anyone has a 2041 that they don't use and want to sell cheap (or rent out for a weekend... ), shoot me a pm. I would really like to try one out.
Trevor i have a 2041 pipe you can borrow for the weekend where you racing at i will see about meeting you there ... also is the 2081 pipe the same as the alpha pipe that out i believe is 2081 too thnx Will G
will g is offline
Old 03-15-2011 | 12:06 PM
  #1723
EBMods's Avatar
www.ebmods.com/kbrl7.htm
Sorry so short everyone, in the moddle of relocating the shop to a newly built building. Trying to be back up and running by Friday the 18th.
EBMods is offline
Old 03-15-2011 | 02:57 PM
  #1724
Officespace's Avatar
Default Tuning Issues at the PNB
I bought a new .21 race prep to use in my buggy at last week's Psycho Nitro Blast and struggled with getting a decent tune with it all 4 days. Granted it was brand new when I got to the race, but I ran through 2 tanks on my starter box, then ran 3 tanks very conservatively on the track in my buggy. It ran fine when I was putting around the track, but when I started to get on the throttle after running the 5 first tanks, I couldn't get it to tune. (Running Byrons 30% and OD 97T plugs) I leaned it an hour on top from the box stock settings and it ran OK, then after a few more tanks, I leaned it another hour to start to work on my race tune, but it still wouldn't clear out on top. I tried several pipes - 086, 2039, 2050 and 9901, but it still wouldn't produce much top end. I tried leaning it out 1, then 2 hours more, with each of the pipes, but then I started to lean bog. Needless to say, it wasn't easy to run competitively during qualifying. (Lean bogging right before the huge triple made me come up way short several times and I broke an a-arm in 1 qual.)
Any advice on what I'm doing wrong or what I need to do to get this engine to run? I'm not going to give up on it yet, but the engine was definitely NOT ready for a race tune right out of the box!
Officespace is offline
Old 03-15-2011 | 03:04 PM
  #1725
jpalessi's Avatar
if you over lean the hsn the bottom will bog. back out the hsn a little at a time till it dont bog coming off the corner, then start leaning the bottom till it rips and idles good. the top wont really come alive till after about a gallon of fuel.
jpalessi is offline
