Sirio engines thread
#916
afm, thanks for that write up on the following page. Very informative.
You mentioned that it was OK to run 30% with stock head clearance. I just bought an EVO3 T3 and a gallon of 30%. I was thinking of using Josh's break-in procedure. Do you think I will be OK breaking in with 30% without shimming?
Any help or experience from anyone would be greatly appreciated.
T
T
#917
Anyone ever seen a big block more powerful than this http://www2.towerhobbies.com/cgi-bin...?&I=LXEPH9&P=7
#919
Originally Posted by Racing4Evo
Hi,
Does anyone who has an EVO 3 know if the crankshaft is hardened and silicone filled like the WCR?
I'm getting one of these engines soon for a big race.
#920
Hi,
#921
Originally Posted by jeffreylin
I think it is Peter from looking at the picture on their web site. I am getting one next week too.
#922
Originally Posted by Top Gun 777
Defenetly hardened. Crank is 12 mm with bore 8.6 mm, turbo scoop is pretty small. Lowered cooling head over the case. At list this version we got 2 weeks ago, not sure if this team version or market version.
#925
Looks awesome then.
Have you tried the pipe yet?
I get my Evo3 in a couple of days. Ended up getting a 3 port per your suggestion. I am going to break it in this weekend and I will let you know how it is.
#928
Originally Posted by kidDynomite
I need to break-in my EVO3 by this weekend. Does anyone know if I need to shim the head to run 30% or am I better off just using 20%?
#930
Use sirio 6 plug. This should give you a good starting point.
1Likes
