Like Tree1Likes
Sirio engines thread
Old 03-04-2005 | 10:48 AM
  #856
uaerc's Avatar
Default Engine break In
Helloo.....
I just broke in the first few tanks on my 12 tup today. it was just a great feeling.... The flywheel was impossible to to turn had to prime it really good to do so...I used a OS P6 plug which was just great. did the break in as per the site's videos. I ran the car on the ground after the 3rd tank i am not running more than half throttle most of the time except for the usual full speed bursts at times. The power looks good and all. But i feel that the clutch is not engaging properly or might be slow.
Do we need to change the cluctch shoe on the v one rrr for the sirio. ?
any other pointers till i restart the break in again, as i just did one tank on road, coz my main shaft ering came off and i had to come back to get another one.
uaerc is offline
Old 03-06-2005 | 03:31 PM
  #857
shiston's Avatar
Hi,
Does sirio make any exhaust systems that will fit a TG10mk.2 or FW-05R chassis? If not, what would be the next best thing?
I know Mielke make one that will suit.
Cheers
shiston is offline
Old 03-13-2005 | 04:44 AM
  #858
rowveg36's Avatar
guys, is the 12wrc sirio worlds replica engine modified or stock? i saw one at rc-mushroom for $330 w/ a legal pipe. is this a good deal or what? thanks for any info:
rowveg36 is offline
Old 03-13-2005 | 05:26 AM
  #859
uaerc's Avatar
I am yet to start re-breaking the engine probably this weekend. when i am running it rich does it matter if i give full throttle or not coz the engine does not reach full RPM anyways.
As mentioned in the catalog where they say do not run at full speed > which i presume means at full rpm not full throttle ?
Whereas once you are at Half turn more than than the optimum you are in any case not going to reach the so called full speed ? isntit ?
or if no we need to just keep it a bit rich than usual and not go full throttle ?
keeping in mind this would be my 4th total tank and 2nd tank on ground first 2 tanks were run in off the ground as per sirio site.
Please enlighten me someone ?
uaerc is offline
Old 03-13-2005 | 05:50 AM
  #860
TRAJ's Avatar
Originally posted by shiston
Hi,
Cheers
I dont think they do
This pipe is great and so is the Kyosho 2piece one
http://www.skylinercracing.com/store/P_35.htm
TRAJ is offline
Old 03-13-2005 | 05:51 AM
  #861
TRAJ's Avatar
Default Re: Engine break In
Originally posted by uaerc
Helloo.....
The clutch might be engaging cause the engine is still rich at run in.
TRAJ is offline
Old 03-13-2005 | 11:59 PM
  #862
HarKonnenD's Avatar
Post
Anyone know if the 3 or 5 port Evo 2 can hang with an RB V12 3 port turbo. For the price the RB is quite expensive and if it's not that much faster than the X12 as they say, then I'd want something with more power for my huge track and for bashin in the parking lot. MY LHS has one for $170, but not sure if its the earlier Evo 2 or the latest Evo2. I read somewhere that they also work better with shorter gear ratios? My current gearing on the HPI is about 6.5:1 first and 4.4:1 on second (I'll get the actual numbers later). Think that will work fine? I'm just trying to find an engine good in price, but with a lot of power. Not able to get the RD logics or Palmaris engines.
HarKonnenD is offline
Old 03-14-2005 | 01:30 AM
  #863
hello from France,
The new Sirio Evo 3 set TQ in top class at the first round of the french championship.
New case, new piston/sleeve
Nice engine, lot of torque.
romuald31 is offline
Old 03-14-2005 | 01:36 AM
  #864
MTX-3 Kid's Avatar
EVO 3 what the they only just came out with the WCR
MTX-3 Kid is offline
Old 03-14-2005 | 08:45 PM
  #865
Originally posted by romuald31
hello from France,
bennylee is offline
Old 03-14-2005 | 08:53 PM
  #866
Racing4Evo's Avatar
I would definitely get one of those engines! I gone through 2 gallons of hard racing with my Evo 2 and it has been strong all the way through. I think the pipe I am using fits the engine very well. There are no flat spots in the power band. I think the best part is fuel economy. I seem to be getting better run time than the Novarossi motors.
When can I get the EVO 3?
Racing4Evo is offline
Old 03-14-2005 | 09:11 PM
  #867
HarKonnenD's Avatar
Which Evo 2 have you been running and how much run time?
Old 03-15-2005 | 07:16 PM
  #868
Racing4Evo's Avatar
I don't remember the part number but it's a 3 port SG shaft and turbo button. I think S12 TRP 1?
Old 03-16-2005 | 10:50 AM
  #869
HarKonnenD's Avatar
Kewl. I'm debating on that 5 port or waiting for the LHS to get the 3 port legal one.
Old 03-22-2005 | 06:26 PM
  #870
shiston's Avatar
Hi,
I've only every used novarossi C7TGF turbo gold plugs on my .12 engines.
Is the Sirio S001720127 turbo plug S7 cold exactly the same as the novarossi C7TGF turbo gold plug or the non gold plug?
Cheers
shiston is offline
