Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 08-19-2009 | 06:59 PM
  #1321
r1harper's Avatar
so i would be just as happy with the Toro.. is there anywhere the toro is better.
r1harper is offline
Old 08-19-2009 | 07:08 PM
  #1322
houston's Avatar
from 160ft. to 500ft.
there is no end to the upper end of that thing
houston is offline
Old 08-19-2009 | 07:13 PM
  #1323
r1harper's Avatar
k thanks
r1harper is offline
Old 08-19-2009 | 07:14 PM
  #1324
r1harper's Avatar
does the 086/9886 work well with it...i love the power of this pipe.
r1harper is offline
  #1325
Trevor Williams's Avatar
R/C Tech Elite Member
I ran a ToroNero of Monty's.......WOW....that thing was ballistic!
Trevor Williams is offline
Old 08-19-2009 | 07:18 PM
  #1326
houston's Avatar
thats what trevor drove
fast , definitely fast
41021 or 41020/9886
need one ?
houston is offline
Old 08-19-2009 | 08:05 PM
  #1327
r1harper's Avatar
thanks but i have two already...
r1harper is offline
Old 08-19-2009 | 08:19 PM
  #1328
Props to Monty for doing a great job on his motors, I ran the H.E.S. Toro last weekend at the Futaba challenge and it was flawless. I was running the 6.5 restrictor with an ofna 053 pipe with 30%byrons and pitting at 10 minutes during the main. Actually during practice I twice got over 12:20 out of it before I ran out of fuel and the motor absolutely screams, anyone who purchases this motor will be very pleased. I ended up finishing fourth after I bobbled in the last corner before the loop otherwise I would have finished 3rd in expert arena truck, not to bad considering I qual'd 4th but was hacked into 11th after the first lap.
WideOpenThrottle RC is offline
Old 08-19-2009 | 08:22 PM
  #1329
Monty, the FMS is on it's way to you tomorrow. I understand it's got a little more bottom than the Toro and I wondered which pipe would give it a little more grunt down low and less top as my home track doesn't have a very long straight, even with the smaller restrictor in my Toro I can't use all the top that it has.
Old 08-19-2009 | 10:33 PM
  #1330
houston's Avatar
try a header such as the one adam likes , the 41021 with a 9853 (or the ofna 053) and you will get a little more bottom but will sacrifice some top end performance . it will fall flat in the upper rpm's
houston is offline
Old 08-19-2009 | 11:51 PM
  #1331
air8's Avatar
Martin did you race the truggy in your avatar at the Omaha RC Pro Series? If so that Toro sure was torquey. Someone pointed your truck out to me and I got to marshall 1-2 of your qualifiers. That truck was off the hook in my eyes. FAST!!
air8 is offline
Old 08-20-2009 | 04:36 AM
  #1332
OfnaJoe's Avatar
Hey, just checked out the 21-5K on your website again and was wondering if you had it in the turbo version or if you even liked the turbo over the standard plug? I put a turbo head on my RB WS7II and it woke it up!
TIA Joe
OfnaJoe is offline
Old 08-20-2009 | 04:40 AM
  #1333
OfnaJoe's Avatar
But I was thinking that with this engine a standard plug would be better in a buggy with its more linear feel over the turbo.
TIA Joe
OfnaJoe is offline
Old 08-20-2009 | 07:00 AM
  #1334
Yep I was there, the bottom is smooth but plenty strong and when it gets into the midrange look out.
Old 08-20-2009 | 11:45 AM
  #1335
OfnaJoe's Avatar
OK guys, all this talk on here made me go ahead and order a 21-5K with the HES mods and R2R break-in, now just to wait on it to get here
The website suggest a 063 pipe, It looks like on here a 053 pipe is best, which one? And I have a almost new RB2045 pipe, wouldn't that work as good or better than a 053? it is the pipe of choice for 5-7 port RB's and they are Nova based engines.
OfnaJoe is offline
