Houstons Engine Service H.E.S.
#8852
#8853
Suspended
How you doing they say your the man for info on nova rossi engines, I bought a used P5 and putting a new rebuild on it, motor had no head shims, I plan on running 25% fuel, can you help me out on where to start on head clearance. Thanks, JT
#8854
on that standard configuration of 16.26x16.8 I would recommend .80mm to start and after its broke in (a gallon or so) go to .70mm by replacing the copper .20mm with a copper.10mm
hope this helps
#8856
#8857
Suspended
got my shims today plan on breaking in this weekend, do you recommend using a used rod,I got one in decent shape not to much slop, would rather stretch out a used rod instead of new one, dude this piston sleeve is tight!, feels like it will stretch out a new $50 rod. shouldn't take near as much run time to break in a new rod, any thoughts would be grateful, Thanks, JT
#8858
Preheat your engine for first gallon n a half or so and it will not wear nearly as fast
#8859
Suspended
Thanks, So, I'm going to pull the new rod, break in 80% with used rod , swap back out and finish break in with new rod, then pull the #10 shim, should be good to go for a few gallons. some extra work but new rod should be a lot tighter, last longer, hopefully, Thanks, JT
#8860
your engine most likely did not come with any .10mm but rather 2 x .30mm and 1 x .20mm , imo pulling the .20mm is a bit much unless you are running 20% fuel.
#8861
Suspended
Dude, I am doing what you said, breakin with .80 pull the .10 out after a gallon, runnin 25% have to, got three gallons left to burn, did find those aluminium shims like you said two of them no copper shim, used my micrometer to put .80 together, all good, swapin rods is easy, use a plastic bag(wrist pin clip!), Thanks, JT
#8862
another awesome weekend running FUSION X ENGINES !!!
good job to newly joined team driver Cody Grams on 3rd in 8th buggy
NCT RD#1 columbia cup
#8863
#8865
its not 100% necessary but i find the shoes wear in better an more evenly
i got quite a bit of time on the buku clutch systems
btw .... i received a large order of buku clutch stuff
22Likes
