Houstons Engine Service H.E.S.
#708
I am picking up a hm nova 528xr off of Monty real soon, cant begin to say how excited i am about this !!
Just a couple of questions , as im new to "real" Italian mills.
I 'm running a LST2 so im restricted to my header selection , right? aswell, now ive got a losi high tq tuned pipe , supposed to be 086 copy?
any suggestions.
Plug type?
fuel ?
have to start stocking now cause LHS is POS
thanks for the help
any suggestions.
Plug type?
fuel ?
thanks for the help
#709
Monty a friend has a 367 that runs at 295 or so. Flames out on landings of jumps. Not from clutch bell hitting chassis. Mugen aluminum w/1.0 springs. Odonnell fuel. Standard button #6 plug. It's the first time in over 15 years we've seen this with a Nova Rossi. Can you help please ?
#710
any suggestions.
Plug type?
fuel ?
thanks for the help
any suggestions.
Plug type?
fuel ?
thanks for the help
i think this engine liked odo97t , 6$ a piece
byrons gen2 race3000 30/11
.28 engines have a 1/3 more cubic displacement , so pipes dont act the same on them .
use a 53 based pipe if you can but whatever you run on it will work .
#711
does the engine idle on bench ?
imo , i can tell you that the 367 engine loves a little higher deck heighth (shim at .90mm) a turbo combustion chamber with a hotter glow plug ( odo77t ) .
i can only make suggestions over the pc , it is very difficult to assess a problem with an engine and diagnose without having the engine in hand .
from what i can gather you have experience in nitro if you have been doing it for 15 yrs. .
there is no problems with the car it is being ran in ? fuel tank , fuel lines , plugged pipe and all the obvious stuff i take it .
when you say it runs at 295* , does that mean it wont run at all at lower temps ? or that is where it makes the power ?
hope this helps ,
monty
just my opinion
#712
p5xs...what can I expect after running plus4?? I seen one at the track the other day and it looked/sounded awesome....thinking about picking one up, I love my plus4 though, and you will be seeing it soon for TKO's/service, Im home chillin if you wanna ring me up
#713
Monty we have been racing nitro since 1993. R/C in general since 1988. We thought about adding a shim to raise the deck height. On the box it will quit some times. It's in a 5T that is only one race old. The engine isn't raceable unless it's at around 295. It's only 70 degree's outside. The engine doesn't have a gallon on it yet. To quit and run inconsistent is just driving us nuts. It will fine in the pits. Goto the track and it will quit. The engine has always been pre-heated before being started. His other Nova's have been fine.
It's a standard plug. The turbo button has been out of stock for a long time. The engine has a Nova Rossi #6 in it.
hope this helps ,
monty
just my opinion
hope this helps ,
monty
just my opinion
#714
1 gallon of running on the novarossi engines is really not enough fuel ran through to start racing it and expect any kind of real power .
friction creates heat , keep running it and keep the temps in 230-240 range and wait for the power to come up and temps to drop . then full race tune
does the engine tune and run consistently ?
if it does not then there is a fuel delivery issue somewhere or an air leak in the equation . probably not the engine . novarossi engines seal up awesome
monty
if you want me to help you out with it you would have to ship it here
#715
Monty yeah it's pretty consistent when it's running. When you say deck height. Are you measuring from the top of the sleeve to the top of piston at TDC ? Then measuring the distance the button goes into the sleeve and subtracting it ? To get the deck height. What should the deck height be with a standard button ?
#716
if you put .85mm or .90mm you will be better off , if you use a turbo comb. chamber such as 28011 or 28022 / 28022/1 i think you will be more pleased with the engine .
finish breaking it in before passing judgement on it though
hope this helps ,
monty
like i said if you want me to play with it , LMK
#719
#720
the square header always has a lean bog feel on the 086 pipe . it gets worse as the pipe starts to lose volume from build up
22Likes
