Like Tree6Likes
Team Orion Engines
Old 05-26-2011 | 07:16 PM
  #781
ScottyM's Avatar
Originally Posted by j_blaze14
2056 work? its supposed to be smoother with better runime than the 2013
2056 is the "bat" pipe if I remember correctly, and I have yet to see any engine it has really helped with.. Maybe the .24 engines, but even those seem better off with the 2057.
ScottyM is offline
Old 05-26-2011 | 08:52 PM
  #782
Hi, Scottym, Pitpop or anyone
You always help me here... so
I have a Team Orion 5 port abi crf with 2057 pipe i am using the 2057 with the extension like you told me....
so i also have a 2035 AE pipe ,the 2035 works great with Reedy and OS engines, do you know or tried this pipe with Orion engines?it works?
Thanks again
Marco23 is offline
Old 05-27-2011 | 08:53 AM
  #783
ScottyM's Avatar
Thanks again
I have no first hand knowledge, and I know this won't be comparing apples to apples, but Ron from Werks, has recommended the use of the AE 2035 to guys with a real tight budget on the Werks b5 engine.. The Werks and Orion are made in the same factory, so it may work well (IE better then the 2057) on the Orion. Ron's feedback was that power is nice, but run times suffered slightly when compared to the 2013, but for the $$ it worked very well..
My opinon is this. Since you have the 2035, take a day go to the track then tune the engine to the 2035 pipe, and see what it does.. Worst thing is you get to spend a day at the track.. And who knows it may become your secret weapon..
ScottyM is offline
Old 05-27-2011 | 11:03 AM
  #784
pitpop's Avatar
2035 should work fine.. funny thing about Orion engines, they will run good with just about any pipe, but they are just a little happier with 2013/2058.
pitpop is offline
Old 05-27-2011 | 02:23 PM
  #785
BIGTIME's Avatar
Thinking about trying the 3 port, will a O.S 2060 work? Not trying to buy another pipe..
BIGTIME is offline
Old 05-27-2011 | 02:26 PM
  #786
KThatcher's Avatar
Yes will work good... really helps the top end on the 3 port I really liked how it felt just hated how quite the 2060 was
KThatcher is offline
Old 05-27-2011 | 02:33 PM
  #787
BIGTIME's Avatar
Which 3 port did you run?
BIGTIME is offline
Old 05-27-2011 | 03:00 PM
  #788
KThatcher's Avatar
Both the old ABI non CRF and the new CRF version
Old 05-27-2011 | 06:16 PM
  #789
Which pipe gives better runtime on the crf 3 port, the 2057 or 2058?
yamahamxracer is offline
Old 05-27-2011 | 11:55 PM
  #790
v6shooter's Avatar
+1
v6shooter is offline
Old 06-01-2011 | 07:53 PM
  #791
Default Inuiry on glow plug
Greetings to all, i am Dr.Gerald Lo from the philippines. I was given by my brother from L.A a Team orion CRF ALPHA .21 ABI 5 port off road buggy engine Cody King edition #55/500. it came with a Team orion plug #6. My question is what other types of glow plug could i use with the engine as there is no Team orion dealer here. the only available glow plugs here are the novarossi , o.s brands.thanks in advance for the help guys it is much appreciated.
doc888 is offline
Old 06-02-2011 | 05:39 AM
  #792
Ultraspeed84's Avatar
p3 will work in the motor and be easy to tune on!
Ultraspeed84 is offline
Old 06-02-2011 | 08:39 AM
  #793
ScottyM's Avatar
P3 or P4 should do the trick.. Make sure the taper from the Orion and the OS match pretty close, though. A different taper can cause some leaking which will make tuning a nightmare.. So if your going to run an OS plug then I would start with and OS plug and just shelf that Orion plug..
ScottyM is offline
Old 06-02-2011 | 05:50 PM
  #794
@Ultraspeed 84 and @ Scotty M - thank you so much for the info on the plugs.
doc888 is offline
Old 06-03-2011 | 09:42 AM
  #795
Hey,
I'm new to the forums so please go easy on me. I have a Team Orion Combo CRF Alpha Engine ABI (ABC/7 Ports/Ceramic) w/2057 pipe running on a losi 8ight 2.0 buggy and was wondering if 30% nitro fuel can be used??? The instruction guide to the engine said I can use up to 25%. Also would I get a better performance on top end if I use a 2058 pipe?? Any feed back and advise would be highly appreciated...
Gaspare is offline
