Like Tree6Likes
Team Orion Engines
Old 06-03-2011 | 09:45 AM
  #796
Default Question!!??
Hey,
I'm new to the forums so please go easy on me. I have a Team Orion Combo CRF Alpha Engine ABI (ABC/7 Ports/Ceramic) w/2057 pipe running on a losi 8ight 2.0 buggy and was wondering if 30% nitro fuel can be used??? The instruction guide to the engine said I can use up to 25%. Also would I get a better performance on top end if I use a 2058 pipe?? Any feed back and advise would be highly appreciated...
Gaspare is offline
Old 06-03-2011 | 02:35 PM
  #797
ScottyM's Avatar
Originally Posted by doc888
@Ultraspeed 84 and @ Scotty M - thank you so much for the info on the plugs.
You are Welcome. I help when I can..
ScottyM is offline
Old 06-03-2011 | 04:11 PM
  #798
stallen50's Avatar
what runs time are you guys getting or should i expect with orion abi 3 port motor in a d8 with 2013. i also have 2035, dynamite 053,086 pipes.i am new to orion, but i also run werks too. just wanted to try something different. hows the power compared to like nova p5 old version?
stallen50 is offline
Old 06-03-2011 | 04:19 PM
  #799
stallen50's Avatar
darn phones
Old 06-03-2011 | 04:32 PM
  #800
Default Question??
Hey,
Gaspare is offline
Old 06-03-2011 | 06:37 PM
  #801
ScottyM's Avatar
I've not run the 3-port, but has seen a few.. They seem to me to be very similar to the V-spec, but with a bit more punch on bottom. Most of that added punch I think is the 2013 pipe. Even with the 2013 they lack nothing on top end.. Run time, that I seen were right at 11 minutes to out of fuel. So 10 minute pits are possible on a smaller track..
ScottyM is offline
Old 06-03-2011 | 10:03 PM
  #802
Hey,
Gaspare is offline
Old 06-04-2011 | 11:52 AM
  #803
pravesh736's Avatar
Default new engine
hi all ..
i just ordered for the team orion world champion jared tebo edition .. can anyone tell me the differences between the orion crf alpha 5 port and the world champion edtion 5 port ... because i can see the crankcase is not coated and wat r the other differences between dem if ders more .. please let me knw ..
pravesh736 is offline
Old 06-04-2011 | 06:21 PM
  #804
Good morning Guys , it's me again from the Philippines....i ran 1 gallon on my CRF .21 C.King edition and was really surprised at the engines power. i really love it. but i now have this problem....1) could i replace the orion plug that i used with a o.s p3? have no where to get an orion plug here. 2) i can't remove the piston sleeve of the engine.any tips how i may do it? Thank you so much Guys for bearing with me...
doc888 is offline
Old 06-04-2011 | 10:47 PM
  #805
Have you tried using the end of a zip strip in the exhaust port and turning the flywheel? That usually works for me with all of my engines. From what PK tells me, the p3 will work, BUT it is definitely not going to be as reliable or durable as the orion plug. Once the motor gets hot, the p3 will be toast. I asked him the same question as well, not to mention the taper on the plug may be different, causing air leaks around the glowplug seat, which will cause tuning to be a nightmare. If you have already ran the Orion plug, it would be wise to stick with Orion.....I cannot get Orion plugs anywhere around me either.....so I am in the same boat as you Amain maybe?
yamahamxracer is offline
Old 06-05-2011 | 12:04 AM
  #806
ScottyM's Avatar
Originally Posted by pravesh736
hi all ..
Port timing will be the biggest difference as far performance goes. I laid Eyes on a Tebo Edition tonight, but it was still new in package, so I can't comment on it's performance yet..
But it if it is as good as my Discovery 5-port it'll freaking rip..
ScottyM is offline
Old 06-05-2011 | 12:09 AM
  #807
ScottyM's Avatar
Hey Doc, Yamaha Racer gave you some good advice on all your questions. Let us know how it goes.. FYI the Werks Plugs are very similar to the Orions, so you might try to get those..
If it comes down to literally not being able to get them, then test a plug that you can get. Do it like this.. Check compression with an Orion plug. Switch it to a plug you can get, and if it is any different, then it's not right.. The feeling if different will be very slight, if you notice any difference at all. If you are set on OS, I would recommend a P4 - P6, as the P3 is extremely hot..
ScottyM is offline
Old 06-05-2011 | 12:43 AM
  #808
v6shooter's Avatar
YEAH.That Discovery rip it is a powerhouse makes alot of power and good milage too.
v6shooter is offline
Old 06-05-2011 | 01:36 AM
  #809
pravesh736's Avatar
thanks a lot .. u always help me out ..thank u again ..
but wat is the difference between the discovery and the tebo edition ..??
will the tebo edition have more power than the regular crf alpha 5 port or smthng up down ??
thank u
Old 06-05-2011 | 03:06 AM
  #810
Default Scotty M
@ Scotty M - thanks so much. I will inform you in a few days on what happens when i use the o.s plugs.
@yamaha racer- thank you for the information.
doc888 is offline
