Team Orion Engines
#48
sure, I think that is the hot plug, right? It should be fine. We use the Orion or Sirio #5 and 6. #6 for when it's hot out, like over 85 degrees. The p3 also works, but not as durable. The Orion plug is a great plug and developed with this engine technology too. I can honestly say that no matter what engine we ran, knowing what I know today, the Orion plug is one of, if not THE best glow plug on the market. More power and more durable.
I just re-read that.... a Picco plug huh? Hmmmm......
#49
jimmy, why are you in here making confusing comments?... NO, the Orion plugs are not related to Picco in any way. Team Orion has their own plugs developed specifically for the Team Orion ALPHA line of engines, and manufactured in Italy if you are really wanting to know...
Now, I wanted to answer some questions here that I got about the Alpha standard plug edition. I think the easiest plug to use is the McCoy MC9 for the standard version. Also, the 2013 pipe works best on all the Team Orion ALPHA line of engines.
#51
#52
Now this is what I'm tawkin' about!!!
2010 Team Orion Alpha CRF, new configuration, new crank, new aluminum carb! These new mills are the shizz... check it out on neo-buggy:
http://www.neobuggy.net/modules/news...p?storyid=7502
#54
#57
It came with 7.0 mm Venturi adn we always use that one.
The new Combo kit will be with 2057 pipe in Europe ... dont know about US ( 2013 is not allowed in Europe).
David drove the CRF Alpha 3-port at Nitromania and he liked it very much.
#59
Hi Anthony. I don't know what might come in the box, we have been putting the new carbs on everything and I haven't seen the production stuff. Probably like Pierre said, maybe 7. We run 7 on the 3 port. Anything less and Cody stands on the trigger and the mileage goes down.
I'm not sure on the bearing sizes, but I'll check into it. FYI it's also the same size as the Sirio if that helps.
#60
6Likes
