Team Orion Engines
#1532
Can you guys give me a good starting point as to where the idle gap screw and lsn should be ? im trying to break this thing in gotta get it to idle ?
It is a Cody King edition.
#1533
I typically use the radio, and adjust the trim until it will continue to run, for the first few tanks..
#1537
.60
#1540
I finally got to run the buggy at the local track properly with the 5 port Discovery in it. I had put the new head button and LSN in it before I left and all I can say is WOW! The thing was insane!
I have about 3/4 of a gallon threw it and left the HSN at about flush or a little in from flush and turned the new LSN in until it came alive. The throttle response was almost instant and it has a lot of bottom and mid-top with the 2058. The sound it made was awesome too..... Braapppp! Can't wait to try the 2013. I'm running byron's 30% /9% with the #5 plug at almost sea level in cool dense air. Very impressed!
#1541
I had one wait until 1.5 gallons to drop its nuts and another drop them at .5 gallons. Too many factors to say when it will finally break-in..
#1543
#1544
#1545
Hi,
Got a five port orion and think one of the bearings may have gone. I'm hearing an odd noise when reving the engine. Kinda sounds like cicadas chirping. Odd I know but I can't think of any other way to describe it. The engine idles smoothly enough and generally sounds Ok aside from the odd noise. The only thing I can think of is that a bearing is gone. The pitch of the noise changes depending on the revs. Any thoughts?
Thanks.
Thanks.
6Likes
