Like Tree6Likes
Team Orion Engines
Old 02-15-2012 | 01:41 PM
  #1381
Randall rc's Avatar
Smile orion jtp vs os 21 vzb speed powerbands.
Hey. I need you orion guys honest opinion. Does the orion have a smooth powerband like the os speed vzb. Not the xzb speed. Particularly i want to knw if the jtp combo is smooth. And worth every penny.
Randall rc is offline
Old 02-15-2012 | 02:47 PM
  #1382
ScottyM's Avatar
IMO no.. The midrange has a slight rich point that cna cause some tuning issues, but keep the bottom end fairly lean, and run a hotter plug then you might have in the OS, and it pretty much goes away, but still isn't quite as smooth as the VZB. I however do feel that slight rich point hlpes put the power of the engine to the ground by keep wheel spin down.. It has its advantages....
ScottyM is offline
Old 02-16-2012 | 08:10 AM
  #1383
Hi guys I was wondering....... how do you guys think the 2013 pipe would do on the jtp engine versus the 2058 that it came with? Thanks In advance!!!
Joey98 is offline
Old 02-16-2012 | 02:24 PM
  #1384
ScottyM's Avatar
It'll do like every engine that has the 2013 pipe mounted to it. It'll make a touch more bottom, and a touch less top end.. And it'll sound way meaner..
ScottyM is offline
Old 02-18-2012 | 03:33 PM
  #1385
dfsc10's Avatar
Whats the best break in procedure for the JTP edition? I thought it would come with a manual with orions break in procedure but it didn't.
dfsc10 is offline
Old 02-18-2012 | 10:02 PM
  #1386
Originally Posted by pitpop
Yes, I absolutely recommend greasing all the o-rings, seal the rubber boot, and make sure banjo fitting is sealed. Your carburetor and engine will be happier this way. It's so nice to have accurate tune and idle laying down in the corners.
Hi guys,
About to receive a JTP 5 port in a few days. I wanted to make sure I sealed up the carb correctly before I run it in. Found the info above but I don't understand completely.
Is there a particular type of grease that should be used to seal the o-rings and the rubber boot?
What is the banjo fitting?
Any other pointers on sealing the carb would be great.
Thanks.
ratjayfala is offline
Old 02-19-2012 | 11:15 AM
  #1387
dfsc10's Avatar
Originally Posted by ratjayfala
Hi guys,
Thanks.
+1
dfsc10 is offline
Old 02-19-2012 | 06:35 PM
  #1388
ScottyM's Avatar
The Heat Cycle method seems to work very well, breaks-in fairly quickly, and has good life.
Hi guys,
Thanks.
+1
I think Pitpop uses a Kyosho grease for greasing the o-rings and other rubber. The Banjo fitting is the fitting where your fuel line attaches to the carb.
ScottyM is offline
Old 02-20-2012 | 03:44 PM
  #1389
erc55's Avatar
i found that orion engines like rich hsn and lean lsn. more than os and novarossi. have any of you experienced this also?
erc55 is offline
Old 02-21-2012 | 05:37 AM
  #1390
ScottyM's Avatar
Yes to keep the Midrange smooth you need what will seem like a lean bottom. The HSN will be typical for all other engines, IMO..
ScottyM is offline
Old 02-21-2012 | 06:45 AM
  #1391
When tuned 1-2 hours rich from lean bog on bottom its perfect then tune top to power or temp u like since i started doing this and sealed my carb up good motors run and idle perfect with great runtime.
Little tip by ise motor seal on banjo and oring where carb goes in case.
I glue the carb slide boot on and let it rip
jewn_beef is offline
Old 02-22-2012 | 09:07 AM
  #1392
Hi guys,
I can get a Orion JTP combo for ~ 260$.
Just want to ask if you would wait for the new engine line or just buy the JTP edition?
Is it possible to make 10 min. pit stops with the JTP engine?
How would this engine perform in a buggy?
reel is offline
Old 02-22-2012 | 08:02 PM
  #1393
Jammin57's Avatar
Who is running the blue head Orion in the kyosho
http://gallery.neobuggy.net/2012Race...994558_xpBs2Sd
Jammin57 is offline
Old 02-23-2012 | 05:53 AM
  #1394
ScottyM's Avatar
Maybe Mr. Paul King can let us know when he gets back..
I know it is sweet looking..
ScottyM is offline
Old 02-23-2012 | 05:55 AM
  #1395
ScottyM's Avatar
Originally Posted by reel
Hi guys,
I'd say get the JTP, good price for a limited edition engine and pipe.
Engine could go 10 minutes with a good throttle finger and good timing, but your safer at 9-9:30 pit stops.
That engine with the 2058 pipe in a buggy is excellent.
ScottyM is offline
