Like Tree2Likes
RB Concept Engine Thread..
Old 02-17-2009 | 11:48 AM
  #121
PinoyCali, from what I have seen. The C6 would be a great for a truggy. I do not know what pipes people are using.
Shooky is offline
  #122
Eccentric's Avatar
Get some Associated Green Slime O-ring grease and lube the o-rings up with that. Works great for shock o-rings too (that's what it's intended for).
Eccentric is offline
Old 02-17-2009 | 11:58 AM
  #123
I have tried Slime on carb needles and found that the needles liked to turn due to the vibration. Maybe it just happened to me.
Shooky is offline
Old 02-17-2009 | 12:04 PM
  #124
Eccentric's Avatar
Stuff did its job too well I guess. Maybe just use a tiny amount. It's worked for me...
Old 02-22-2009 | 12:59 PM
  #125
BIG RE's Avatar
what do you guys have as far as needle setting on a ws7III with %30byrons and a hot plug? I went to go buy a new #6 meduim plug for a race this last weekend, and the shop didn't have any so I got a mccoy59, I could not get the damn thing to run, and ended up getting frustrated and messing up my settings trying to figure it out.
BIG RE is offline
Old 02-25-2009 | 08:48 PM
  #126
losi 8t's Avatar
Only thing i've hurd bad bout the RB S5's...are that they dont last all that long...and of course this is based upon HOW u drive it also...but thats bout the only negative thing...unless someone can prove me wrong? i was thinkin bout gettin the S5 for my Losi 8T....but dunno if it will last long enough..any input would help!!! thnx.
losi 8t is offline
Old 02-25-2009 | 09:53 PM
  #127
rallyebmx's Avatar
I've got a brand new in box RB Concept C6-BBT II L2G that I'd be willing to sell for $380 shipped if someone wants to jump on it before it goes to Ebay......
rallyebmx is offline
Old 02-26-2009 | 06:29 AM
  #128
mfrosty's Avatar
Quick question, can I use an MC9 plug with my C6BBT?
mfrosty is offline
Old 02-26-2009 | 07:36 PM
  #129
JPMSRacing's Avatar
R/C Tech Elite Member
From: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
I just found this thread, I just bought another C6 this morning, it sucks to be slow, it will be another month before I can fork out for another engine, I wouldnt trade that C6 for nothing, all the tracks in the state for the most part are tight and the bottom end of the C6 you can just hug the pipe at almost a stop and blip the throttle and your over the next big jump. That engine dropped me 4 sec a lap at my local track from the V-Spec I was running.
JPMSRacing is offline
Old 03-02-2009 | 05:01 PM
  #130
BIG RE's Avatar
turbo plugs only in the C6 as far as I know, I don't own one
BIG RE is offline
Old 03-02-2009 | 06:55 PM
  #131
diamondracing's Avatar
S5 is a strong engine with a good amount of top w/ 2045 192 set-up.
After one gallon put new front bearing and rod and you will be happy. I run it in a buggy at nitro challenge and it would easily keep up with just about everything except my C6
diamondracing is offline
Old 03-03-2009 | 05:33 AM
  #132
aznitronut's Avatar
You can use any turbo plug in the C6, the MC9, I think is a cold plug, depending on where you are, ( cold country and cold plug don't do well) unless you just need that challenge, the RB 6 turbo plug works well.
aznitronut is offline
Old 03-03-2009 | 05:36 AM
  #133
mfrosty's Avatar
Mine uses a std plug. It's the old head not the L2G. Plug definately has the copper washer on it.
mfrosty is offline
Old 03-03-2009 | 05:44 AM
  #134
aznitronut's Avatar
If your in Baltimore, and the weather as cold as it is, it's best to go with a hotter plug, the MC59 will be okay, it's hotter than the MC9, and the RB 6, you could even use an RB 4, it's just a lot easier to run with the hotter plug in the colder weather.
Old 03-03-2009 | 06:35 AM
  #135
TXRC8racer's Avatar
I own a RB S7 standard plug which I use a RB#6 plug in and im using the same plug that it was broke in on and I have been thru 1 1/2 gallons so far and can not complain at all and not changer a plug!! I have had people tell me that motor screams im also using a JP3 pipe. And im getting 8 1/2-9min on a tank and temps running 220 or so, and this is not a modded motor either!! But the one thing I will say that my LHS can not get parts for them or at least plugs, I know the RB#6 plug at amainhobbies.com have been on back order along with alot of other hobby shops and the only place i have found them was towerhobbies.com.
I don't think I will own a diffrent motor for a while, But i have been looking on Ebay for a turbo head for tunnning reasons I have heard they are a little eiser to tune...
TXRC8racer is offline
